Results 1 to 10 of 27
- Mar 2005
- 16
March 8th, 2005 11:14 PM #1i need help regarding my mitsubishi 1995 gli.
lumalabas ang check engine light and everytime it does nag-je jerk ang sasakyan.
dinala ko na sa casa ang kotse pero sabi nila ayos naman daw ang computer box at servo.
ano pa kaya ang puwedeng problem. sana mas nakakaalam sa inyo.
nagpalit na rin ako ng spark plugs two times pa within 3 days dahil mali daw yung unang kinabit. kaka-replace lang din ng timing belt ko.
- Dec 2004
- 430
March 9th, 2005 12:11 AM #3
it can be anyone of these: bad fuel, dirty/clogged fuel filter, broken MAF sensor.
Signature
March 9th, 2005 01:43 AM #4
San ka nagpakabit ng spark plugs? anong mali sa pagkakakabit? where do you gas up? and what fuel do you use?
March 9th, 2005 11:35 AM #6
Di ba pwede nilang malaman ang problem by extracting the error code. Ano daw ang error code?
- 106
March 9th, 2005 12:34 PM #7my officemate experienced this sa lancer nya just last week.
jerk plus check engine (parang sinisinok yun kotse)
nun dinala sa casa, walang error code na lumabas sa MUT.
here are the things done:
replace servo (he has 2 lancers, so exchange lang)
clean throttle, injectors
clean fuel tank and line
replace hi-tension wires
since tapos na ang mechanical check, they started looking at the electrical system
culprit:
defective alarm system which caused grounding of the ecu
Tsikot Member Rank 3
- Dec 2002
- 551
March 9th, 2005 12:53 PM #9Originally Posted by laurence
March 9th, 2005 12:57 PM #10
just had a similar problem last week (though walang check engine light).
nilinis ko first ang MAF sensor... no effect...
then change ng spark plugs & adjust a/f mixture... ayun... ok na!
change fuel filter ka rin...
Automatic po Sir
