Results 5,911 to 5,920 of 6542
April 9th, 2019 10:59 AM #5911
The important number is the first one; M14. It's a metric screw that is 14mm in diameter. The last number is the length of the bolt in cm. Both 1.5 and 1.25 cm bolts will fit your Ertiga.
There's usually a 2nd number that specifies the thread pitch, but it's been omitted in this case.
April 9th, 2019 12:01 PM #5912
- Nov 2014
- 454
April 9th, 2019 07:56 PM #5914
- May 2019
- 11
May 4th, 2019 02:37 PM #5915If you use fully synthetic engine oil but with lousy oil filter, it is also wasteful. The main point is to change more regularly if you use semi syn or medium, then your car will be fine. It all depends on your budget.
Sent from my Mi-4c using Tapatalk
May 4th, 2019 05:32 PM #5916
During my short stint in Seattle, the BMW X5 I drove requires an oil change interval of every 10,000 miles or 16,093 kms! When I brought it in for service, they used the BMW TwinPower Turbo 5w-30 fully synthetic motor oil (approximately 7 quarts). I asked the service manager on why it takes 10,000 miles for an oil change? He reasons out that the weather in Seattle is relatively cool (average of 52 degrees F or 11 degrees Celsius) and stop and go traffic is isolated during rush hours only. This explains for an extended oil change interval using a fully synthetic motor oil - cold ambient temperature and lesser stop and go traffic.
May 4th, 2019 05:50 PM #5917
May 4th, 2019 06:30 PM #5918
May 5th, 2019 07:24 PM #5919
May sale sa handyman kanina, 30% off on Castrol FS, bale 1,050 na lang, kaso 15w40
May 21st, 2019 06:42 PM #5920
Guy Tries To Use Banana As Engine Oil In His Car
Xiaomi E-Car
