Results 5,251 to 5,260 of 6542
December 20th, 2017 06:24 PM #5251
if you want good fc that 0w20 would be best..
December 20th, 2017 10:15 PM #5252
ATF DW-1 replaces Z1, wala ng Z1 sa casa, baka meron sa labas, but I would advise you against it, baka ma jafakes ka pa.
Valve clearance is recommended to be checked every 20k based on booklet, I never had mine checked ever because I don't go to casa.
Sa oil so far I have been using FS with Mitasu as my latest, same performance pa rin sa Mag 1 FS, Idemitsu Mineral Oil and Honda Genuine Mineral Oil, so since I only cover 3.5k kms/6 months and use only Vic filter, balak ko mag Honda Mineral Oil na lang every 6 months para tipid. Sa casa, quick chamge oil, all-in is P1,195.00 for regular oil. Honda Cars Philippines' Official Website
- Jun 2017
- 32
December 21st, 2017 11:04 AM #5253Thank sir StockEngine
Nakita ko din yang promo/ads ng Honda sir Papi Smith. Parang gusto ko na lang avail yung semi synthetic. Iniisip ko lang kasi dyan, baka matagalan bago makuha ang oto dahil sa mahaba ang pila though meron akong appointment bukas for airbag replacement baka pwede ko na isabay sa change oil after ng replacement.
Same lang pala tayo, 3.5km din sakin for 6mos. 7mos pa lang sa akin tong oto
Btw mga sir, hindi daw advisable ang 0w-20 fs oil dahil sa klima dito sa Pinas? Dapat 5w-30 or 10w-40 daw?
December 21st, 2017 12:16 PM #5254
Bro, quick oil change yung promo, 1 hour guarantee or you pay nothing yan dati, ewan ko lang ngayon.
December 21st, 2017 01:35 PM #5255
a thicker oil helps in racing(where theyre pushing above 5000rpm and producing 500hp+ for over 1hr). sa metro manila parking lot you dont need that thick viscosity oil and you only need 20-60hp in 8kph speeds 😂😂😂
- Jun 2017
- 32
- Jun 2017
- 32
December 21st, 2017 04:41 PM #5257Sir StockEngine and sir Papi Smith, ask ko lang kung ilang liters ang kailangan na ATF kapag mag diy na palitan yung fluid?
(Sorry po, OT po ulit)
December 21st, 2017 04:47 PM #5258
Better let our Jazz owners here answer, mine is a 2013 Civic and it uses 2.6 liters.
January 1st, 2018 06:39 PM #5259
Question po.
I own Accent Hatch CRDI, sa manual, nakalagay na oil is 0w30, 5w30, 10w30 and 15w40. Does it mean na safe gamitin ang 5w40 dahil may indicated na mas thicker oil (15w40)?
Also, is it safe na 10k kms or once a year yung OCI ko using Shell Helix Ultra Diesel (5w40)? Sa province po ako nakatira na walang trapik tulad ng sa Manila.
Thanks po sa sasagot.
January 1st, 2018 06:41 PM #5260
you can use naman the 40w. so while youre reading the manual, whats the recommended oil change interval? whats the oil capacity? whats the required diesel engine oil? api-cj? or acea class?
Monk-owned R53
