Results 6,381 to 6,390 of 6542
August 5th, 2022 10:23 PM #6381
My simple mind tells me that when a vehicle calls for a certain mileage or time when to change the oil and does not specify anything except for the 5w30 whatchamacallit thingie, I take it that mineral oil will just do fine.
With Facebook, I realized people tend to baby their vehicles, to the point of asking what's your bling or asking what bling do they need to put. So I also understand why most people who only use their cars every so often try to overthink what's the best oil to use.
- Jan 2008
- 4,726
August 5th, 2022 11:55 PM #6382
August 7th, 2022 12:39 AM #6383
using amsoil on innova, so far so good. shifting is smoother, less effort sa arangkada than previous casa oil.
- Jun 2005
- 3,772
August 7th, 2022 01:21 AM #6384Diba placebo effect?
Sent from my 2107113SG using Tsikot Forums mobile app
- Feb 2014
- 2,536
August 7th, 2022 11:23 AM #6385
placebo effect lang yan. during the 90's we used thicker oil and you really notice a difference after changing the oil
but starting late 90's early 2000's when you change the oil you don't notice anything
btw i just recently changed to amsoil on the ford, no difference at all
August 7th, 2022 11:47 AM #6386
August 7th, 2022 01:57 PM #6387
Based on my experience parang pare pareho lang ang performance ng oil sa car ko. I've tried Mobil 1 FS, Honda Genuine Mineral and a lot of other FS and mineral oils, regardless if they are fake or not, may time talaga na parang magaan ang takbo at meron ding time na para kang may hinihila.
Except one time when I used 20w50, na nabibigatan ako sa hila, I don't know if it's psychological, because everytime I use the car, first thing that goes to my mind is nasilaw ako dahil mura itong Toyota genuine oil only to learn later na mura talaga ang 20w50. But if I press the pedal harder, responsive naman sya.
- Feb 2014
- 2,536
September 18th, 2022 07:39 PM #6389
full synthetic daw. mura. shows a real API donut so it's officially certified (xteer for example doesn't show the donut)
pero walang acea ratings so it has the same specs as a 10w30 mineral oil like valvoline premium conventional or havoline formula. similar price as these two mineral oil also
September 19th, 2022 09:08 AM #6390
Wala nang Mineral Oil ang Honda.. Semi and FS na lang daw ang choices..
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
