Results 6,171 to 6,180 of 6542
October 27th, 2020 09:03 AM #6171
I noticed that what you are refering to are recommendations from the manual. The question is whether the Casa follows that recommendation cause My brother’s New Montero & Fortuner’s oil cans just say for “recommended for diesel engines” but does not specify the ACEA class, just the SAE grade. Apparently, recom in the manual is different from what they actually do in the casa here & we all know sakit na ng casa yan. When I asked the Advisor in my casa why they arn’t using the right oil? Sagot sakin “basta po pang diesel”. Using the specific oil will actually extend the drain interval, you know.
October 27th, 2020 01:16 PM #6172
October 27th, 2020 01:32 PM #6173
October 27th, 2020 01:42 PM #6174
Yup, last I checked it was C3 naman.
Current diesel API ratings are CK-4 and FA-4.
API | Oil CategoriesLast edited by Wh1stl3r; October 27th, 2020 at 01:47 PM.
BANNED BANNED BANNED
- Sep 2015
- 13,919
October 27th, 2020 01:59 PM #6175ang ayaw ko sa europeans eh sila nagmanipulate ng emission testing ng diesel car nila na malinis-kuno. Hindi ko lang alam kung kakuchaba si ACEA
mas may tiwala ako sa kano pag ganitong usapang kasi mga anti-diesel yan.
Kung talaga low sulfur eh si dexos 2 ata.
October 27th, 2020 02:12 PM #6176
Found an updated packaging for that same bottle with a still current CH4 rating form toyota san jose's website although yun synthethic is still CF/SN in that regard mas okay ung kay mitsubishi CJ-4 for synthetic and CI-4 for mineral still older than the current CK4 standard though.
- Apr 2012
- 3,469
October 27th, 2020 03:25 PM #6177
October 27th, 2020 03:35 PM #6178
It tool me some time to find a VW-rated diesel oil for our Jetta TDI. Nanigurado lang ako nakasulat yung VW/Audi 504.00, 507.00. Pero same lang eto na ACEA C3, GM dexos2.
I used Amsoil European Car Formula 5w30. Medyo mahal din at 700+ per quart. Much affordable than the 1k rate the VW casa is charging us.
October 27th, 2020 06:43 PM #6180
Have you checked the range of oils of Cyclon? They have a lot of oils there which are VW, BMW, Merc rated. This oil is made in Greece but is Euro Standard. And its a lot cheaper. The Cyclon Magma Syn TDI costs P1,730/4lit jug. I’m sure there is an oil there for your Jetta.
Products – CyclonLast edited by bloowolf; October 27th, 2020 at 07:04 PM.
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
