Results 6,061 to 6,070 of 6542
November 13th, 2019 02:30 PM #6061
Motor oil smell in the cabin? Impossible.
Apart from the combustion chamber, the engine is pretty much a closed system. The little oil it ejects as a by-product of blow-by is ingested back into the combustion chamber to burn off. If you have an issue with oil consumption, it'll be out your vehicle's tailpipe. There is no way it can enter the cabin. And if you have a problem of exhaust gas coming into the cabin, you'll be smelling exhaust fumes before you smell the burnt oil.
The odor is likely from adhesives, upholstery or materials around the area where the cabin floor meets the firewall. That's usually where the hot exhaust pipe from the engine or even the cat passes through in close proximity. That area is also close to A/C intake and so it can easily be mistaken to be an issue with the A/C. You see, running at a sustained high RPM makes the exhaust pipe very hot... even glowing red in extreme situations.
I noticed the same with my then 07 Civic FD. If I do some spirited or aggressive driving (4-6k RPM), I will immediately smell trace odor of something burnt coming out of the A/C vents. Scared me in the beginning. Eventually, as the adhesive or material cures, the odor becomes less and less prominent. By the time I sold the vehicle 7 years later, the odor was gone.Last edited by oj88; November 13th, 2019 at 02:35 PM.
November 13th, 2019 06:07 PM #6062
This must be the answer to my question. I've been wondering why I smell something burnt whenever I hit 6000 RPM in the Honda City 2010. I told my son to refrain hitting the redline unless necessary, like merging in lane when he's coming from the toll gate. I told my son that he should be at a speed of 60-80 kph so that he won't cause annoyance to the oncoming vehicles, that somehow builds up unnecessary traffic because of slow moving vehicles.
Going back, I don't remember smelling the same thing with Mazda 6 and I was hitting the redline unlike the Honda City. Same thing is true with the CR-V 98.
Is there something wrong with the Honda City?
Sorry, I'm off topic again.
November 13th, 2019 06:08 PM #6063
November 13th, 2019 06:36 PM #6064
Motor Image will allow you to use your own oil as long as it meets the requirement stated on the manual. With my FXT, I have used Motorcraft FS 5w30 and Zic X7 FS 5w30 with no issue at all. I just bought 6 quarts of Mag1 FS 5w30 and I intend to use that on my next change oil (which I do outside of casa already).
Fusion R gives its customers the option to use either Motul or Amsoil. They offer the Amsoil OE 5w30 for 400 per quart, a lot cheaper than the Motul option. This oil meets the requirement of Subaru for their turbo engines - 5w30 viscosity, fully synthetic, API SN/SN+ Resource Conserving, ILSAC GF-5.
By the way, what vehicle do you have with the Honda K24 engine?
- Jul 2009
- 6
November 13th, 2019 07:28 PM #6065Yeah my wife and kids noticed it too the main reason why I don't push it when not needed. The only item that changed is the oil but I won't go back to Helix anymore just to verify. You might be right and it is the adhesive materials being cured so yeah that might explain everything thanks. I did not experience it with other cars though but I admit it will be harder to go higher RPM other than fiesta.
Also I noticed the oil level in the dipstick is not increasing after a few months of usage unlike before where it usually go over the full mark months before the oil change. Compared to the oil level of my FXT which is increasing at an alarming rate the main reason why I wanted to switch to Amsoil on that thing as it might help with the fuel-oil dilution. My route is mostly within Makati within weekdays so can't really burn the fuel mixed in the oil within the DI engine.
- Jul 2009
- 6
November 13th, 2019 07:56 PM #6066I tried bringing Amsoil in MI but they still filled Motul. I know since Motul is pale in color compared to Amsoil. I only discovered it a week after changing the oil. I should have double checked the color but it was under the sun when I checked in in Pasig MI before going back home. They also did not return the half bottle excess since I also bought 6 qts of oil, that should be the flag right there. Was planning to give the excess to the fiesta since it is still not 100% filled in my last oil change I previously go to BGC MI for my PMS but it is already closed. The main reason why I wanted to switch to Amsoil is to remedy the gasoline-oil dilution that I have since I'm mostly just stuck in Makati traffic over the weekdays. The problem with FXT is oil temperature won't even sometimes reach 96C over 1+ hour ride under Makati traffic especially in the morning. I assume going to Fusion R will void warranty?
I don't have a K24 but I'm contemplating between a used K24 CRV and Innova. I won't use it though so I'm leaning over Innova. Just curious how fun it would be in 7000 but then again priorities.
- Jul 2009
- 6
November 13th, 2019 08:19 PM #6067Yup. It must be the adhesive materials burning as oj88 suggested. Agree Amsoil is good, did not expect me enjoying the 8 year old beater fiesta just because of the oil. I can't remember when was the last time it revved that way using the casa oil. Now I don't even have to wait for the idle to drop to 800RPM before moving so it will purr smoothly. It might be psychological but I even ended up liking to drive the fiesta more than FXT in the city after the oil switch but it can't just catch the yellow light that can cause a hefty 2500 penalty. For long SLEX / NLEX driving and rain I still prefer FXT due to NVH and ride height but it is not oil related anymore unless you mention the DI fuel-oil dilution that won't happen in long provincial trips.
- Jul 2009
- 6
November 13th, 2019 09:03 PM #6068Cool. I did not do the actual oil change and brake cleaning, a guy in Motech did it. Just bought the consumables so it is not DIY. I only did the non messy and easy part such as changing the air and cabin filter among other stuff that is outside the scope of this thread.
- Jul 2009
- 6
November 13th, 2019 09:09 PM #6069
- Nov 2019
- 4
November 14th, 2019 12:16 PM #6070Hello, Sir bloowolf!
Apologies for the late reply, was busy the past few weeks and wasn't able to subscribe to the thread regarding your reply.
Took your advise and proceeded to have my vehicle's oil change serviced outside of the casa. Would like to ask for your advise regarding the changes made.
- 5W40 Oil, 5 Liters
- JS Asakashi Oil Filter
- Hyunda Mobis Air Filter
First time to have 5W40 Oil on my vehicle, used 5W30 in the past, but due to the 5W30 being unavailable upon purchase, was resolved to 5W40 instead. Will try using 5W40 and observe for a while.
Anyways, any reviews for the JS Asakashi Oil Filter? Checking the box and it says good for 10k KMS before Oil Change.
Thanks!
sinabi moh! i hardly see my children now. when they were young, schedules were more predictable.
Traffic!
