Results 11 to 16 of 16
January 10th, 2009 12:04 PM #12
Anong car ba sya? Baka valve seat at hindi valve seal ang pinalitan. Kung valve seat pinalitan I think dapat recheck ang valve clearances. Usually sa engine bay cover may mga clearance specs na nakasulat for reference.
January 13th, 2009 02:47 AM #13
Tsikot Member Rank 2
- Feb 2008
- 577
January 13th, 2009 07:35 AM #14proper valve clearance may be found here:
1 - under the hood sticker
2 - owner's manual
3 - factory service manual
not all clearances are the same even for the same make. it depends on the engine
- Jan 2009
- 5
January 16th, 2009 08:52 AM #15thanks po for all the replies. thinking the problem was valve clearance, i had it checked then adjusted to specs na nakalagay sa valve cover. But sadly, ganun pa rin, may loss of power pa rin on acceleration, mas maangil yung ingay galing tambutso upon stepping on gas at yung takbo parang hindi pino gaya ng dati? What could have possible been messed up in replacing valve seals so i can have it checked po?
January 16th, 2009 09:23 AM #16
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
