Results 1 to 6 of 6
- Sep 2009
- 4
September 25th, 2009 12:21 AM #1i have a toyota corolla ae92 16 valve engine,, mauusok poh ang tailpipe white smoke ang lumalabas,, nababawasan ng langis ang makina every week!pero di nman masyadong marami,,, chaka ano po effect kpag tinakpan ang isang butas ng carburetor....? baguhan lang po kc ako parang niloloko lang ako ng mga pinupuntahan kung mekaniko...
September 25th, 2009 12:55 AM #2
September 25th, 2009 01:00 AM #3
One or more of your piston rings are leaking oil into the combustion chamber.
The leak also goes the other way, exhaust gasses can get into the crank. The oil in the engine will get dirty prematurely and lead to increased wear & tear in the lower part of the engine including the crank shaft bearings. This can lead to expensive repairs or a need to replace the entire engine.
The carb has two jets, one is for idle and the other is when you step on the accelerator.
September 25th, 2009 01:07 AM #4
i'm not an expert proxy but i've experienced that last year. i asked expert tsikoteers about it and most of them said that a top overhaul is needed to fix the problem. as far as i can remember, the piston rings, gasket and valve seals were replaced, among others.
September 25th, 2009 01:49 AM #5
Mostly what they do is replace valve seal, Cylinder head gasket, piston ring . Asinta valve para lumapat kung may singaw.
- Sep 2009
- 4
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
