Results 11 to 17 of 17
- Aug 2017
- 232
October 12th, 2017 02:51 PM #11I was there. Nag drain muna siya nung oil. Then may tinanggal siya na metal na madumi then nilinis nya yun. Then pagkakabit ulit, saka naglagay nung ATF na 5 Liters muna, tapos kada liter na dagdag, nag drain ng 1 liter hanggang naging clear ang oil. Tama ba process? :/ Medyo namamahalan ako sa 3k actually. But since malinis naman ang output...
Sent from my EVA-L19 using Tsikot Forums mobile app
October 12th, 2017 02:55 PM #12
Then it's shouldn't be called ATF dialysis.
Ginagawa rin yan ng ibang mekaniko nililinis pati yun strainer.
- Aug 2017
- 232
October 12th, 2017 03:14 PM #13How much normally charge sa ganyan? Yung sa kanya naman is kahit ano papagawa under the hood, sakop na ng 3000. PMS rate tawag nya.
- Jul 2016
- 17
October 19th, 2017 02:06 AM #14
- Oct 2018
- 1
October 15th, 2018 09:11 AM #15Got to meet mang boy last saturday (oct 13) to repair my chevy spark...replacement of shock mount at tie rod...
Magaling po siya...makuwento at mahahalata mong maraming alam sa kotse...pati sa trabaho ok sa olrayt...
Recommended mechanic po si mang boy...
January 24th, 2019 01:22 PM #16
Nice to know nakatulong sainyo sir.
Yun lancer namin namatayan makina pag mainit na makina, hinala ko maf sensor dinala ko na din sa rapide yun kasi malapit sa tinirikan, maghapon nila dinaiagnose ayun sinukuan di makuha problema pati fuel line kinalas di naibalik maayos. Hinatak ko nlng. Pinasilip ko kay tito boy, wala pa isa oras napatino nya, ayos pa daw maf sensor, linya ng electrical nag loose lng pero need din daw palitan crankshaft sensor. Ayos na nmn problem solved nya as usual
kapapalit lng din nya ng clutch ng jimny namin, after mapalitan matigas pa din ng konti pedal rinestore nlng nya cable ngyn good as new bulak ang lambot.
Yun lancer pinalitan din nya clutch.
Radiator ng lancer may tagas palit bago na pero ang mahal kahit sa motorix almost 10k abutin, may nakita sya sa best colt bago 3.5k lng pero need modify konti mounting. Napaubra nya no trace na may modify pulido sya gumawa di pede gamol sa kanya pag gusto ko ng problem solved result at di puro palusot ng mga makaniko dito sa malapit samin sa manila, dinadayo ko tlga si tito boy, iniiwan ko nlng oto sa kanya sya na bahala mag source ng pyesa etc. Mas tipid at wala pagod sakin kesa magikot pako at palipat lipat mekaniko, pinagsasabay sabay ko na pagawa lahat sa kanya..text nya lng ako pag ready for pickup na oto after ilan days, lahat resibo binibigay nya din. Minsan na sablay din sya syempre tao lng haha yun shifter bushing ng jimny wala sya makita pyesa kya fabricate sya ayun bumigay agad, balik ko daw sakanya pero alam ko mahirapan lng dahil fabricate binilan ko nlng pyesa sa suzuki casa 600 lng pala ngyn ok na. Haba na haha, in short mahusay tlgaLast edited by halimaw; January 24th, 2019 at 01:26 PM.
- Feb 2019
- 1
February 19th, 2019 01:58 AM #17Any updates with you guys?
Also ano po exact address ni sir Boy. Oliveros mismo yung malapit sa simbahan po ba?
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
