Results 21 to 30 of 31
- Sep 2006
- 1,335
July 1st, 2010 02:15 PM #22
- Apr 2010
- 13
- Sep 2006
- 1,335
- Apr 2010
- 13
July 11th, 2010 12:49 AM #25The Service people from Hyundai Fort did not specify what were the DTCs They just said there were a lot of error codes and they deleted them. But before that ( when i had it checked in pasig hyundai) the error codes they mentioned was EGR valve . They recommended ECU replacement...Hyundai Fort only recommended to replace high pressure pump and rail assmbly. Also A/c switch and cluster (instrument panel). It has been more than a month and my Matrix is still running ok...FC is now 9k/L it used to be 11k/L .still ok pa naman.
- Sep 2006
- 1,335
July 11th, 2010 10:52 PM #26The Service people from Hyundai Fort did not specify what were the DTCs They just said there were a lot of error codes and they deleted them. The DTCs were inactive codes if they were deleted. An active DTC cannot be deleted unless it has first been fixed.
But before that ( when i had it checked in pasig hyundai) the error codes they mentioned was EGR valve. A faulty EGR can cause high FC.
They recommended ECU replacement...This is possible but I doubt it.
Hyundai Fort only recommended to replace high pressure pump and rail assembly. A faulty high pressure pump and rail will cause a no start condition.
Also A/c switch and cluster (instrument panel). Maybe.....
It has been more than a month and my Matrix is still running ok...FC is now 9k/L it used to be 11k/L....still ok pa naman. 9k/L is not ok. My Matrix averages 14k/L city.
- Apr 2010
- 13
September 23rd, 2010 10:14 PM #27My Matrix is still running. I was able to bring it to Lipa city 2 weeks ago with a full load of people (5 pass) Fuel consumption a bit better. So far so good. Hopefully I can travel farther next time.
- Sep 2006
- 1,335
September 26th, 2010 11:58 AM #28
- Apr 2010
- 13
October 3rd, 2010 12:01 AM #29So far no DTCs
top speed is 100kph , I did not want to push it since Hyundai Global City guys said not to go above 3000 rpm , and since my tachometer does not work i played it safe.I use a GPS to track my speed.
Fuel consumption has gone up. I get 9-11km/liter instead of my 11-17 before Ondoy.
Power seems less than before, I miss the turbo kick i used to get when i accelerate.
At least it still works, I am generally happy with my Matrix, it is in a class of its own.
July 1st, 2011 11:54 AM #30
Hello!
Can anybody refer me to where or How to fix the EGR for the matrix Crdi? I have an 05 matrix which runs pretty well except for the high FC, black smoke (failed emission test), and sulphuric exhaust smell aswel. The car's mileage is only 50Tkms.
tia!
i didn't know differential oil can be... picky. when my 2005 innova swam thru ondoy, i had its...
