Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
    Jan 2003
    #21
    kimpoy
    ano advantage ng tanso radiator top n bottom?
    Aug 2005
    #22
    Quote Originally Posted by jozin
    Hi sir,
    Thanks for the new input. I'll try to remined the mechanic to check the cooling jacket also. Napangiti ako about the Wilkins, di ko po alam, maganda rin pala ang miniral water sa makina.
    Salamat po uli.
    Wilkins is not a mineral bottled water, it is distilled drinking water.
    #23
    Kim, si cody ba yun avatar mo? laki na ah at malago na ang buhok :D
    #24
    Use Distilled drinking water not mineral water. Kaya nga we do not recommend tap water is because it contains solids.
    Aug 2005
    #25
    Thank you sir sa clarification. Any explination why distilled water is good for the engine?
    Aug 2005
    #26
    Check the link http://www.928oc.org/tip/tip514.htm and read the whole article. Hope it answers your query.
    #27
    Simply put, distilled is good because it has been distilled and the solid particles have been taken out.
    Those solids can stick inside the radiator, cause scaling, and eventually foul the system.
    Jul 2005
    #28
    pag bago overhaul or top O/h makina mo,ang susunod na mangyari dyan is clogged radiator tubes.di maayos pag tangal ng head gasket mo-kinuskos then pumasok sa jacket ports.Normaly nangyayari yan pag paspasan ang trabaho ng mekaniko.
    I've already experience that.maybe maybe maybe ganyan din ang nagyari.
    I suggest to check all the components of your cooling system.marami kasing dahilan yong overheating problem.
    Aug 2005
    #29
    Sir Leinahtan,
    Salamat sa link na bigay mo very informative. From now on I'll try saving rain water for my radiator (syempre yung malinis).
    sir jeegoogs, salamat po sa input mo. Yan talaga ang cons ng nagtitipid(di kayang dalhin sa casa). Next time sana maka ipon ako ng malaki-laki para madala ang kotse ko sa casa or sa shop with reliable and dependable mechanic.
    Salamat po uli.
    Aug 2005
    #30
    if you done already lahat cnbi nla at gnon prin bka ala s timing, pg dlayed timing hirap ang engine taas temp mo,pwede rin my warp cylinder head kung matagal magcooldown at mbilis mghigh temp at high speed pwde rin improper torque and sequence ung pakbit ng head ng mekaniko
Mabilis uminit ang makina.
