I use isuzu pick up LS 93model. kakachange oil ko lang ng zepsa, tapos mausok naman na white? suggest naman po kayo para hindi magging mausok ang sasakyan.thanks
white smoke? di ba sobra diesel pag ganun?
Pag black carbon deposit naman. put a garden hose on the tail pipe. pag puno na start the engine...
http://www.dieselsmoke.com.au/
hope this helps.
worst case scenario yung may water contamination. so better have a good mechanic check you ride ASAP sir.
Fasten your seatbelt! Or else...Driven To Thrill!
gud pm... sir/madam... try nyo po ung aero wonder lube... engine treatment po cya... matatanggal po un maputing usok or maitim n usok n lumalabas na sasakyan nyo... trusted n po namin ito... isa sir/madam marami po cya benifits sa sasakyan... like makakasave po kau ng 20 to 25% ng gasulina or diesel pag gumagamit po kau nito at gaganda rin po ang hatak ng sasakyan nyo... if your interested just call or text me at this no. 0920607XXXX or 0916639XXXX... tnx po godbless.....
Last edited by ghosthunter; April 22nd, 2011 at 08:25 PM. Reason: mobile phone numbers removed
