Results 11 to 15 of 15
November 2nd, 2012 12:05 AM #11
pray TS na oil pressure switch lang yan. actually nangyari sa akin yan. kaso shut off kapag nirev ko engine. then on at idle. your decision is right.
November 11th, 2012 09:32 PM #12
Update ko lang....i got my car back up & running. Buti na lang no major problem na nangyari sa engine. as it turnout, may bara dun sa line ng oil pump coming from the oil itself. Culprit is hindi maganda yung oil na ginamit at nagkaroon ng mga pamumuoo which caused the clogging. Oil pan was pulled out and cleaned as well as all exposed parts & oil pump. Flushed 2X with road test before loading fresh fully synthetic oil & new oil filter. Thanks goodness ganun lang ang inabot.
November 11th, 2012 09:44 PM #13
- Jun 2005
- 3,774
November 12th, 2012 12:14 AM #14
November 12th, 2012 10:48 AM #15
SKS daw yung ginamit ng mechanic. Will use GTOIL next time & test it on my other car. Malapit ng mag due ang PMS.
Monk-owned R53
