Results 1 to 5 of 5
- Mar 2006
- 106
May 29th, 2008 06:29 AM #1Hi guys,
Hope you can help me on my Lite Ace 93 model,
Monday:
Sea Oil Premium ang ginamit ko nung nagpagas ako. 700 pesos- buong araw ko ginamit wala naman problem.
Tuesday morning:
Nagpalagay ako ng distilled water at sinabi na kailangan palitan ng radiator cap kasi napansin ko madalas tumataas ang temp.
After that, mababa lang talaga ang temp nya the whole day ginamit ko- bukas ang aircon sa harap at likod. Malamig na malamig ang aircon
Tuesday afternoon:
Nagpakarga ulit ako ng gasolina- Caltex Premium kasi nabawasan so nagpadagdag ako ng P350, pinatay ko ang aircon sa likod.
Tuesday Evening:
Napansin ko na sa SLEX nung gabi eh nanginginig at nagjejerk mildly yung andar nya pag low speed at low gear tapos pag bumibilis nawawala yung nginig at jerk.
Dati naman hindi sha ganito. Kung kailan di na tumataas ang temp biglang nagkaganito naman-
Ano po kaya ang nangyari sa liteace ko at ano ang dapat ko gawin ngayon?
May 31st, 2008 05:07 AM #3
bro, tama mag palit ka na lang muna ng fuel filter baka kasi may contaminant ang fuel mo or may tubig na nakapasok sa fuel line mo at na trap ng filter mo yon at syempre hirap na ang flow nito, mas maganda sana kung may fuel analysis around the corner, try mo i-drain( not all fuel) bawasan mo ng kaunti ang fuel tank mo kasi baka may tubig under it.. Try to check the spark plug and electrical system...
May 31st, 2008 05:35 AM #4
Or, you can check the air intake tube is most likely bad, I mean not bad as a very bad maybe just a pinhole and really that hole makes a lot of diff. the tube is between the throttle body and the air flow meter. If its leaks air in the air flow meter even a pinhole may kunting cha-cha so check the ribs on those hose carefully.
- May 2006
- 41
June 15th, 2008 07:28 PM #5hmm baka rin nag sira na yung isang spark plug mo.. pag idle ba nanginginig rin? nangyayari yan sa liteace ko dati.
Shame they could have went with the fortuner V(that is not mentioned in brochures at all) route of...
All New Toyota Corolla Cross
