Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Jan 2008
    Quote Originally Posted by speedyfix View Post
    you need to know the proper sequence for the bolts. minsan hindi lumalapat yung gasket if you don't sequence it properly.
    +1, kahit ilang ulit mo kalasin and ibalik posibleng mag-leak pa rin kung hindi tama pagkakalagay.
    Aug 2007
    I thought I had a leak also on the pan gasket..buti na lang..sa drain plug pala..so new washer lang nilagay.
    pa engine wash mo muna and thoroughly dry the engine bago istart. baka sa upper part ng engine yun leak like a half moon gasket sa top? anung engine ba ito?
    Quote Originally Posted by biboy28 View Post
    gurus , I noted leaks under my engine sa oil pan ata
    feeling ko gasket ang palitan.. tanong ko kung ano pa pwede pang palitan na parts..
    kailangan bang i chgnage oil pag na g palit ng gasket??
    tnx
    Don't guess, get a good mechanic to check for the source of the leaks.
    Oil can leak from a number of places on an engine. Guesswork wouldn't help solving it.
    Oct 2005
    Sir ano po ba proper sequence ng bolts? Simula ba sa gitna palabas or sa dulo papunta sa gitna na sabay ang magkabilaan na turnilyo? Thanks po.
leaks
