Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    guys,
    nabutas radiator ng 05 trooper 4jx1 ko.
    sa casa 58k daw new radiator
    18 k sa walco (not genuine)
    6k yung surplus.
    i heard hindi raw repairable ang mga platic radiators?
    wich should i get?
    my dad tells me na mag surplus nalang anyway masisira din daw naman ulit.
    need urgent help.
    thanks tsikoteers.
    Sep 2004
    Hehehe, AFAIK, Calsonic is a manufacturer of air-conditioners (compressors), di naman yata sila gumagawa ng radiators.
    Try mo kung meron ang Evercool for Isuzu Trooper. Locally-made, pero highly recommended by HCP peeps. Actually, sa 97 Accord ko rin, Evercool. Going 2 years na, going strong pa rin.
    Sheesh, 58k for a radiator?! Grabe tumaga ang casa ah!
    Jan 2009
    Depending on the extent of the damage, you may want to consider repairing it yourself. Just do a Google search.
    If done right, you've nothing to loose.
    time to compare the walco price to jayson's. or evercool natin dito sa levin banawe.
    Quote Originally Posted by Galactus View Post
    Try mo kung meron ang Evercool for Isuzu Trooper. Locally-made, pero highly recommended by HCP peeps. Actualy, sa 97 Accord ko rin, Evercool. Going 2 years na, going strong pa rin.
    akala ko nga rin at first baka condenser eh. pero radiator talga. asked walco and casa and they say calsonic talaga ang brand.
    where to contact evercool dealers sir?
    how much inabot sa accord mo?
    TIA
    tolits :hi: :bwahaha:
    may contact info ka sa dealer ng evercool?
    TIA
    Sep 2004
    Mga 8k+, circa 2007. Speedyfix ang nag-procure, kaya dun ko na rin pinakabit (along with other mechanical works the Accord needed at the time). Via credit card kasi eh. Mas makakamura ka pag direct from supplier, kaya lang cash payment gusto nila eh.
    For far less than 58k, you can buy a brand new aluminum rad designed for racing. May sukli ka pa.
    bro, pwede favor? pa PM naman po number ni migz herrera. nagpa reformat kasi ako ng cp nawala yung numbers ko sa kanya and sa speedyfix.
    metal top naba yung evercool?
    TIA
    Im sure Calsonic also makes Radiators. They make a lot of OEM parts specially for Nissan and Isuzu.
    These days of mass-production and subcontracting, you would be shocked what companies are making for each other.
    My friend's Porsche has stereo speakers made by NOKIA, would you believe?
    Nov 2007
    replaced it with evercool rad. you can search for their website and you can buy it in their plant in laguna (more savings) or you can buy it in banawe. Yung neighbor ko nagpalit na din ng rad ng trooper niya and since he worked in laguna, doon na din siya sa planta bumili ng rad.
    Quote Originally Posted by Esnie.com View Post
    hi esnie.
    do you know what engine does your friend have? 4jx1 or 4jg2?
    TIA
    kamusta pala heat dissipation ng evercool?
    Nov 2007
    Quote Originally Posted by s_quilicot View Post
    hi esnie.
    do you know what engine does your friend have? 4jx1 or 4jg2? as far as i remembered 4jx1
    TIA
    he's happy with the performance of evercool, carbon copy daw ang rad na nabili niya sa evercool kahit daw yung connection ng strout (not sure kung correct ang spelling ko/) ay tugma din.
    TIA
    :hi: SG, dealer ng evercool ang levin automotive parts sa banawe. tel 711-4057/711-4129. baka may pang trooper sila. kung oem naman mas mura sa jayson's (1540 a. rivera near bambang mla.) kumpara sa walco. tel 253-6735 / 712-1489.
    thanks tolits sang side sila? sa e.rod?
    btw, si SQ ako!!!
    :bwahaha:
    btw, si SQ ako!!!
    hi SQ antok pa :sleep: 95A Banawe St. add nila dito sa side malapit sa e. rod. tawag ka muna mga 9am para gising na rin si misis dun :bwahaha:
    thanks sir tolits
    naka evercool karin ba?
    thanks sir tolits
    OEM pa rin sir but once kailanganin evercool na
    just called levin,
    pang trooper
    evercool - 10k "tanso" daw so repairable.
    tyc - taiwan - plastic -5.5k. unrepairable.
    settle nalang kaya ako sa evercool?
    for me much better than surplus.
    your opinion guys?
    almost all the mechanics said to me that it is not repairable kasi plastic daw.
    kahit sa banawe ganun sabi.
    Aug 2006
    Get the evercool brass tank for peace of mind.
    Else, find a good surplus brass tank and have the tubes cleaned and tested for P300-500 labor cost.
    Saang part ba ang leak? kung sa plastic case baka puede pang irepair.
Leaking plastic radiator (calsonic)
