Results 11 to 15 of 15
February 4th, 2006 11:40 AM #11
Dude diba normal lang ang behavior nyan? AFAIK what you're describing (high rev on cold start, etc) happens on all servo-equipped cars. When your compressor kicks in the servo detects the added load and adjusts the engine's idling accordingly.
February 4th, 2006 11:54 AM #12Originally Posted by SeminaristaKuno
February 4th, 2006 11:58 AM #13
I don't know if it's possible. Baka kasi hard-coded sa ECU ang rev and load values. Those who have Nissans should be able to help you. Sa Lancer ko kasi isang screw lang sa taas ng throttle body ang adjustment. When my mechanic adjusted my idling the aircon and all other accessories were off. You don't have to touch the throttle cable adjustment anymore.
February 4th, 2006 12:22 PM #14
what do you mean by "i don't have to touch the throttle cable adjustment" yung "nut that adjusts the throttle cable? uhm... i don't usually touch that, what i can't seem to find is the throttle screw & a/c actuator screw (if there's any with efi' engines).
thanks btw.
February 4th, 2006 12:25 PM #15
Dont have pics but you can't really see the screw per se. It's just a screw head sunk into a hole on top of the throttle body. HTH.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
