Results 1 to 5 of 5
April 8th, 2008 07:33 PM #1
Hi gurus need help on the following or any suggestions and comments is greatly appreciated
I have a 96 Lancer EL nka ayos with sounds, 17 na legue na mags and Pioneer HU with Rockford fosgate na 10 inches but problem is ung engine pag cold start nanginginig at namamatay at carb engine pa ito after a while ok na siya sa suspension naman matagtag at nararamdaman mo ang groove ng kalsada at lagi sumasayad pag nababako. Naka park lang kasi sa garage namin ito lagi due to these problems pero other than that mileage is very low 54k palang we bought it way back in 96 paint is good and everything engine and suspension lang kaya di ko magamit last few months at may tumutunog sa steering column
TIA
April 9th, 2008 10:26 AM #2
the nginig after starting can be a cause of several problems like:
a) Servo
b) Fuel Lines
c) Electrical
yung sa steering column, probably worn out bushings sa steering column.
yung tagtag can also be causes of several factors:
a) worn out shocks
b) worn out bushings
c) underinflated or overinflated tires.
April 9th, 2008 12:11 PM #3
Thanks!! meron ba ito servo kahit fuel injected kasi sa 05 lancer namin bumigay ung servo ang mahal buti warranty sabi naman ng Casa actuator daw pero not familiar with actuator
Pinaayos ko lang aircon ko today wala sila makita singaw pero sumingaw ang freon weird could it be related because hindi siya ginamit for a very long time
April 10th, 2008 07:13 AM #4
yep... pg nag high pressure yung condenser/compressor ng aircon, the condenser (yung parang radiator sa harap na para sa a/c) has a blow-off valve that releases freon gas to return to normal pressure. pag pirming nag-hihi pressure, eventually you'll run low on freon gas = wala na lamig.
yung tunog ng pag release ng gas parang may pumapalo ng exhaust manifold shroud mo, nakakatakot, parang may sumasayad sa rims na bakal.
April 10th, 2008 10:26 AM #5
Ok thanks kasi worry ko baka compressor na eh mahal 11k ang denso na bago kaya linipat ko na sa grahe para madali ko malabas para magamit ko thanks very much
Suzuki JIMNY [merged threads]
