Results 1 to 2 of 2
- May 2009
- 14
November 13th, 2010 05:19 AM #1Mga kabayan help po papa overhaul ako na makina 4d56 diesel bka may marecomenda kayo kung magkano ang tamang presyo ng mga piyensa na papalitan yung po original replacement parts. pakisulat nalang po ng price ..may estimate po sa akin ang talyer para makakuha ako idea kung tama ang price sa akin..salamat po
dito po yuing list ng
ENGINE OVERHAUL ----LABOR---------------
MACHINE WORKS (ESTIMATE)---
CON ROD BEARING--------------------
MAIN BEARING---------------------------
PISTON PIN BUSHING------------------
LINNER --------------------------------------
PISTON RING------------------------------
PISTON ASSY-----------------------------
FLEXIBLE HOSE--------------------------
BY PASS HOSE --------------------------
SELASTIC ----------------------------------
3 BOARD ------------------------------------
MOTOR OIL -------------------------------
OIL FILTER ---------------------------------
CLUTCH COVER -----(PLEASURE PLATE)
8 PCS VALVE GUIDE --------------------
8 ROCKER ARM -------
OVERHAULING GASKET ------------
ENGINE VALVES ----------------------mga gagawin
- Nov 2009
- 14
November 13th, 2010 09:52 AM #2Hi Wilson,
Yung mekaniko ko, inover haul yung 4D56 Pajero ko. Tuwang tuwa ako sa ginawa niya. Puro original parts. Back to standard lahat. Yung Pajero ko ay 1990 3-door intercooler turbo Pajero na galing Subic. Ang ganda ng emissions ngayon. Kakarehistro ko lang at 0.23 ppm ang emission ko!
Magaling talaga ang mekaniko na ito. Puwede mo siyang tawagan. Francis Tel No. 474 0280.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
