Results 1 to 17 of 17
    Jul 2006
    mga sir nahaluan ko ng kerosena yung oil ko
    kasi ginawa pala dito ng uncle ko yung isang lalagyan ko ng oil eh pinuuan ng kerosene pang linis, ako kanina magtotop up ng oil
    pansin ko ang labnaw, nalagay ko mga less than 5ml
    anu kaya epekto nito?
    pinaandar ko yung auto ko ala naman ako nakita usual.
    except na parang me bubbles yung dipstick kapag inaangat ko
    ty po
    Dec 2007
    Quote Originally Posted by sirmykel View Post
    ty po
    Better be safe than sorry sir... pa-change oil mo na agad yan
    if 5ml lang then wala naman effect but change oil na agad with flashing para sure.
    change oil na agad. even if it's just 5 ml, it will have an effect on the viscosity of the oil. di mo rin sure kung compatible sya with the oil and so it might have effect on the quality.
    tama sila bro. even though its 5 ml lang, it will somehow affect the thickness or viscosity of the oil.
    to think na ang kerosene eh nakakalabnaw talaga.
    Change oil na agad bro para walang worries. yung 5 ml na kerosene na nalagay will serve it’s purpose of flushing dirt sa internals… good it's very minimal.
    Nov 2003
    ok sya for flushing minsan pero do not leave it in. drain it and replace it.
    Jul 2006
    nakapag palit nako oil nag mineral muna ako then siguro after 2 weeks palitan ko na ulet ng usual oil ko. haaay kainis talaga
    imho, you don't need to change to your usual oil after two weeks, you can use that oil for three months or around 5000 kms. then you can go back to your original oil later. just ensure that the oil is changed before this period. para hindi naman sayang ang pera.
    isang question pa, when you had it changed/drained, did you change your oil filter?
    Jul 2006
    yes pati oil filter palit na rin kahit bago pa huhuhu
    neways po cguro 3000 kms palitan ko na lang sya kapag nakapag ipon na ulet
    Dec 2007
    change engine napo pra sure at safe
    Jul 2006
    Quote Originally Posted by forcemajeure View Post
    waaaa no money hehehe
    grabe ndi naman cguro ganun kalala pa yung nangyari para change engine na
    ok naman takbo na ng auto ko ngayon cguro nakatulong pa para matanggal pa yung ibang nakasabit sa loob
    change oil nayan bro .. switch to Royal Purple narin .. hihii
    ok maka-react ah... hehehehehehe.
    Ohoy imagine for 5 ml lang na gaas papalit na tayo ng makina, luffffeeeettt!
    Nov 2003
    sayang pera kung papalit ka makina just for that. hehe!
Kerosene sa engine
