Results 21 to 30 of 31
TheOneThatIs
- 1,306
January 4th, 2008 12:22 PM #21
- May 2004
- 102
January 5th, 2008 07:56 AM #22kerosene is ok as it is use by mechanics to clean engine parts, removes residue and even washes dirty hands, downside is pag may natira sa loob that's when the problem comes in cgurado halo yan sa new oil mo and 100% sira viscosity ng oil so the oil will not function as i has to be LuBRIcate.
better use quality engine flushes.
info: STP engine flush is kerosene
January 5th, 2008 01:24 PM #23
January 5th, 2008 01:35 PM #24
In my opinion, as long as you change oil according to PMS or shorter (4000klm) everything will be ok. If you think your oil sump is full of debris and contaminants, pulling down the oil pan is the best solution.
- May 2004
- 102
January 6th, 2008 09:00 AM #25oil based engine flush. meaning oil din sya w/ detergents to removes slugde. try opening a can of STP amoy at kulay plang kerosene na kerosene na.
January 6th, 2008 10:24 AM #26
actually, no need para sa engine flush. just drain the oil overnight while the vehicle's tilted.
or if you have the means, used compressed air to flush out the used oil in your engine.
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 6th, 2008 12:07 PM #27actually pwede naman. pero it has to be a super diluted concentration mixed with engine oil. no way should you use it na puro...
January 15th, 2008 05:45 PM #28
- Nov 2003
- 3,849
January 20th, 2008 02:27 PM #29yup we can pero it will be charged differently and is not included in the promo price.
January 24th, 2008 02:31 AM #30
pakbet na lang yata ang hindi made in china... pati bamboo sticks, fabrique au chin na rin. heh...
2024 Manila International Auto Show APRIL 4-7,...
