Results 11 to 14 of 14
- 34
January 15th, 2004 01:22 PM #11kung hindi 1 liter per week ang kinakaing oil, sigruo 1 liter every 2 months, okay lang ba i delay muna ang pag pa overhaul? what are the consequences kung due ka na for overhaul pero hindi mo pina overhaul? thanks in advance!
January 15th, 2004 04:08 PM #12
Kung 1 liter every 2 months, oks pa yun. Im not sure lang, pero lalala lang ata yung symptoms pag di mo pinagawa.
January 15th, 2004 05:11 PM #13
oil consumption in engines can be attributed to a lot of causes. it may be valve seals, leaky gaskets sa crankshaft, oil pan or other outlets. if valve seals this may give off white smoke also expecially during startups and when the engine is cold but would disappear once hot. to make sure pa compression test mo na lang. hindi mo pa ba na valve set ang hilander mo since brand new? dapat at least once a year ito ang tune up ng diesel.
January 16th, 2004 06:14 PM #14
Yep, compression testing will help determine what exactly can be the problem (i.e. wet and dry testing)...
Monk-owned R53
