Results 31 to 40 of 45
- Jul 2008
- 485
July 30th, 2012 05:09 PM #31I just had the MAF Sensor of my xtrail replaced and throttle body cleaned due to loss of power at high revs. My xtrail cant go beyond 60 kph even if i floor it. verdict of casa: my K&N Drop in filter. had it installed for the past 7 years and the MAF and throttle body has to be cleaned 2x already and this time, the MAF sensor has to be replaced to the tune of 5K+. now my xtrail is back to OEM air filter and i didnt feel any loss of power. my advice, stick with OEM airfilter.
July 31st, 2012 03:08 PM #33
IMO, even on the stock filter it would still be the same problem most likely as the years go by and mileage goes up. If the Xtrail engine is as finicky as the QG on the N16 Sentra (2001-up), the MAF sensor would need cleaning every so often to keep its air flow readings consistent and to have power at the high rpm range, even if you're using a stock air cleaner. Cleaning the MAF is a pretty straightforward item as long as you have the proper hex wrench/screwdriver and some electric contact cleaner.
- Jul 2011
- 262
January 16th, 2013 10:04 AM #34
January 20th, 2013 08:19 AM #36
Been hearing quite often that using K&N drop-in air filter will eventually foul-up the MAF then the turbo later. But K&N disproved this thru there studies, they even have a video on their site about this. But confused really as been in Berrima the other day and they ask me to have the OEM air filter back. K&N is not suited for CRDI, so they say. Something to consider? TIA.
January 20th, 2013 10:33 AM #37
Panel or cone? Cones typically don't do anything for CRDIs due to the MAP sensor.
January 20th, 2013 11:58 AM #38
January 20th, 2013 04:47 PM #39
If you have a diesel don't expect your MAF to last past 75000klm without a oil catch can, Your crank case breather is dumping way more junk on your MAF than a K&N ever will. Your actually supposed to clean your MAF at the same interval as your normal air filter changes are supposed to be.
January 20th, 2013 05:33 PM #40
Heck, that's similar to what we see with local gasoline engines with MAF sensors, too. Tuning goes way out of whack and fuel economy goes down the drain after just 60-80k kms unless you clean the MAF.
Daming issue ng SU7:grin:
Xiaomi E-Car
