Results 11 to 20 of 34
November 6th, 2014 10:41 AM #11
Both work great but perform better when you change the sparkplug wires and (if possible) the distributor.
I use a whole set of splitfire products (irridium sparkplugs, hi-tension wires and distributor) on our archaic 1992 sentra. Works fine with me.
- Jul 2010
- 570
November 6th, 2014 01:30 PM #12I prefer NGK. When I am isolating idle problem of my Lancer EL 96. I tried replacing my NGK spark plug with Denso equivalent. I found out that Denso accumulated burnt oil on its gap after a week of use. While my NGK have no oil and color greyish white. This lead me to TOH my engine which I found out that the combustion chamber already accumulated carbon deposits. Due to cheap valve seals I installed in my last DIY TOH 2 years ago.
So, if you want to know if your engine was due for TOH. Place a Denso Spark plug and use it for 1 week.
Here's the picture of 4 DENSO Spark Plug. Only 1 have no carbon or burnt oil.Last edited by Chinoi; November 6th, 2014 at 01:49 PM.
- Aug 2012
- 2,767
November 6th, 2014 08:04 PM #13Be careful sa pagbili ng Iridium. Denso Iridium spark plug is rated for 20k km only.
Denso Iridium Long Life (OEM) spark plug is rated for 100k km. kaya lang, hindi nagpapasok ng Denso Iridium Long Life ang local distributor.
NGK G-Power Platinum spark plug is rated for 48k km. NGK G-Power Platinum is available in most auto supply shops so ito gamit ko.
NGK Platinum IX spark plug is rated for 65k to 80k km.
NGK Laser Platinum spark plug is rated for 120k to 160k km.Last edited by red_one; November 6th, 2014 at 08:08 PM.
- Mar 2018
- 1
March 29th, 2018 12:54 PM #15
I wonder if I should replace my spark plugs already? My FB will be 5 years old in July but only at 60k kms and it starts well and the engine runs just fine. Pwede ko kaya sagadin hanggang 100k kms or till tell tale signs appear? Btw, what kind of syptoms indicate need for sp replacement, if ever I push it past 5 years?
March 29th, 2018 01:14 PM #16
- Mar 2018
- 7
- Jul 2009
- 2,618
March 30th, 2018 10:21 AM #18Even if it is rated for 100k it is good practice to visually check your spark plug for wear or any other indications. Sometime worn plugs initially produce very subtle manifestations medyo keen ka dapat. Without symptoms or looking 60k in a honda fb your sparkplugs might still be in fine condition especially if you use good fuel.
Yes may fake na NGK. Denso im not sure.
While iridium might be considered "better" than ordinary plugs there are some cars that just require and perform most efficient on ordinary copper plugs. Check your manual nga.
- Jul 2009
- 2,618
March 30th, 2018 10:25 AM #19Noon i remember ngk pang sedan BKr or bke ata na ngk plugs nasa mga 108pesos yung denso equivalent model 95pesos per plug.
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
