Results 1 to 16 of 16
    gurus,need your help on how i can install a simota tube type air filter tube on a carb type engine.. do i need to use an adaptor.. if so were to buy and how much.. pls post a pic on sample installation thanks..
    Aug 2004
    It depends on where you live. You'll have to find a shop that knows its stuff and carries pre-fabricated adapters.
    Some shops make do with the elbow bend adapter that just clamps on with rubber and an O-ring, but, from experience, this isn't very stable, and hard bumps can knock it off. (had something like this on the old Sentra)
    What you want is an adapter with a screw threaded through it into the carb, to hold it in place. There are some Simota pieces that do this:
    (non-Simota)
    But some shops make their own, sort of ghetto-looking versions.
    You'll have to shop around to find the adaptor.
    thanks for the reply sir.. ill be also installing it to my b13.. the AF i have is somewhat similar to the pic posted.. but its sort of a short intake.. it comes with a stainless elbow tube that is connected to the filter.. i think it was installed before in a ga16de engine.. were can i buy an adaptor with in the area of makati.. any suggestion sir.. tia..
    Aug 2004
    Don't know the local shops... pero kung Makati ka, you can do a sweep of Evangelista (EDSA southbound, right after Magallanes, between a Jollibee and McDo right after the interchange), lots of places there, and one is bound to have the adaptor.
    ah ok.. thnx sir.. ill try to drop by there..
    May 2007
    mga bossing, meron bang simota na drop-in air filter para sa carb type, magkano kaya yun?
aftermarket air filters
