Bumababa nang 400rpm ko pagbukas nang aircon ayaw umakyat.
Namamatay tuloy.
Ayaw maglaro nang idling ko.
Ano dapat ko kaya gawin dito pinatune up ko na ayaw talaga.
MX6 mazda pala yung car.
Ang sabi sa aircon actuator daw ayaw gumana? Or sa servo?
Namamatay tuloy.
Baka nag seize yung compressor. See if removing the compressor belt solves the problem. If so you'll need a new or rebuilt/surplus compressor, new compressor belt na rin since chances are napudpod yung nasa car mo if that's a seized compressor.
Since I don't have experience with this yet I wouldn't know if turning off the AC might temporarily solve it to make the clutch spin freely. Did you try turning the AC off?
automatic po kasi sya.
ang ginawa ngayon retiming yung belt nyaadjusted na yung valve kasi baka may tukod sofar wala naman pero may lagutok sa makina. Ganun pa din.
Pagpatay AC ganun pa din kaso hindi sya 800 bumababa sya sa 700rpm.
Adjusted na lahat pati timing etc. ganun pa din.
Nag paoil change na ako, atf change, spark plug saka fuel filter ganun pa din.
Pinapalitan ko na din water pump. Pero parang mas nagoverheat sya.
If your car is injector you probably have a problem called "coking". Its caused by sludge building up around the throttle plate. This restricts air flow causing RPM became eratic or non responsive. Buy a throttle cleaner and follow directions on the can. Hope this help.
