Results 1 to 6 of 6
    Vacuum advance ng injector?
    Try to check the idle up solenoid switch of the A/C which is connected to the injection pump via vacuum hose. Troubleshoot diaphram and switch.
    Mar 2003
    btw pansin ko simulang nagkaganito yung sasakyan a month after nagpapalit ng timing belt.
    Wild guess. Hanapin mo wire ng cam or crank position sensor baka loose. Baka hindi nabalik ng mabuti tapos ng palit ng timing belt.
idling problem
