Results 1 to 4 of 4
    Jul 2005
    Tanong lang po.. saan ba ang engine support located sa mitsu adventure? at pano malalaman if ok paba o medyo sira na engine support mo... kasi notice ko lately parang malakas ng nginig sa engine, when my idle speed seems to be fine.. could it be the engine support. need you help... thanks..
    Aug 2005
    Quote Originally Posted by bluechip View Post
    You can visit the MAC (Mitsubishi Adventure Club)
    for auto trans only. ganito gawin mo (you need a helper to this). engage the parking brake, step on the brake pedal hard enough to prevent the car from moving, then put the car in drive then step on the gas harder and look sa engine, pag excessive ang tilt ng makina the support ay sira na. para sa other side naman, same procedure only engage naman trans sa reverese.
    Nov 2003
    you should have around 4 engine supports... have it brought to a shop to check if may sira isa or more than one dun.
Engine Support
