Results 1 to 19 of 19
    Feb 2005
    car is a lancer itlog EL model.
    Here's the thing i noticed with the ride. Bagong tune-up lang yung ride including carb cleaning, new plugs and oil.
    When the air-con is off and is not engaged yet, mataas ang idle speed nya though i dont have a tach, dinig mo mataas talaga. But when the aircon is on and engages, tama na ang idling speed nya. again, based lang sa nadidinig ko. Pero madali naman ma discern yung mataas sa mababang idling.
    what seems to be the problem here?
    Sep 2005
    I think masyadong mataas nga idling yan. We also have the Lancer EL. When the car is idling, tama lang ang idling speed then when you turn on the A/C, tataas ng konti ang idling speed to compensate for the need of power for the A/C. Try to check the "Idle Up" switch.
    Feb 2005
    yeah.. noticed that na mataas nga. alam ko kasi, di naman talaga mataas ang idle, tumataas lang ito once the a/c is on.
    ok, noted na yang idle up switch.. is it the same as the servo? actually, the car can still be used but the high idling results to a poor mileage.
    Sep 2005
    Yun nga eh. Bad trip nga ako sa Lancer namin kse ang lakas lumamon ng gas. Gusto ko nga sanang pa-tignan baka kulang lang sa tamang tune up. Ako lang kse nag papalit ng spark plugs nito eh. BTW, sa kapatid ko yung Lancer. Ginagamit ko lang pag weekend. Feeling ko, tamang tune up lang kailangan nating pareho. San location mo? Taga-Makati ako pare.
    Feb 2005
    Valenzuela aku pare pero manila based dahil nag-aaral. Maybe silip kami kay raymond sarrol ba yun? oki daw yun eh. but still, i want to confirm pa sa problema ng auto. :D
    Feb 2005
    i don't know about lancers, but on my sentra, there is a white plastic knob at the back of the carb, between the carb and the firewall that contols the idle. clockwise to increase opposite to decrease idle. may be different for different cars.
    I had the same problem with my 92 Sentra..without a/c, my idle was fine..between 500 n 1000rpms. Then when i turned on the a/c, it would drop to 500..or lower than 500! n then sometimes while im driving with the a/c on, my car would stall, A/T pa ito. So, i would never use my a/c kasi, i stall..n my RPMs would go down too much. Putcha, i took it back to my mechanic n told him to fix that. So right now its fine. I guess u just have to find the perfect tuning for the idle, so that the car's idle is fine with the a/c on n a/c off.
    Then another time, like u said, my idle without the a/c was about.. 1000RPMs plus. then when the a/c is on, it would go down n be fine. i guess they were trying to compensate the idle with the a/c on. I've had so many problems with my idle, but, finally its perfect.
    Hopefully ur problem gets fixed. just take it back to the mechanic n tell them about your problem, n that you didnt have that problem before u took it to them.
    Feb 2003
    have your servo checked. or maybe throttle cleaning?
    try speedyfix (santolan). search for his contact number here in tsikot.
    Feb 2005
    Quote Originally Posted by KrisKros
    KrisKros, bro, the setting to adjust for the idleup for the aircon is separate/different from the one for the engine idle.
    Feb 2005
    peeps especially KrisKros and Zman, in sentra do you have any idea how much an "idle up" (white plastic knob ) would cost? a brand new or a surplus one? is it true that this "idle up" got worn-out in years time? Im currently having the same problem like kriskros experienced but the mechanic told me to replace it. Thanks bro for the advise
    kapag tune-up kasi, pinapa-on ang aircon ng mechanic bago niya timplahin ang carb settings. pero dapat mas matipid kapag patay ang aircon. my lancer EL naman 6 kms per liter ang fuel consumption.
    Mar 2003
    naku yan din problema ng lancer glxi ko. ang taas ng idling. pag wala aircon 1000 rpms. pag on ng aircon bagsak siya 500. pag cold start lagi ako namamatayan. kunyari sudden stop. eto tinitiis ko na lang kasi mahal magpalit ng servo e.
    Feb 2005
    what is a dash spot (just correct me if the term is wrong)? does this have any relation to the engine's idling?
    Sep 2005
    sa 93 na sentra ko dati may makikita sa tabi carborador round, semi flat, may ruber tube connected from the carb, dko alma ang tawag niya pero tinutulak niya ang accelarator evrytime a/c is on. ang when it goes automatic bababa cya. May adjusment cya at the back, lubog pag naka on ang aircon nakalabas kapag hindi. try checking yung vaccum nya, pull out the rubber and if sumisipsip pa.have it check it seems like the na set yung carb mo on high dahil dna umaandor ito.
    Apr 2005
    try to adjust yung idle up mo...or try to change the vacum hose ng idle up mo kasi minsan may butas na din yung hose and hindi nakakakuha ng enough vacum yung idle up mo kaya hindi nagfufunction.. 10pesos lng yung per feet.. gastos ka lng ng 100 for the hose..sobra pa yun
    May 2005
    sakin din after tune-up bigla tumaas yung idling niya. ginagalaw ba yung minor niya? tapos tumataas baba yung rpm then back to 1300rpm. dati 700 to 1000rpm lang before tune-up. ngayon nasa 1300 na.
    Aug 2005
    Quote Originally Posted by onedayoldchick
    IMO pag nka tuned up ka linisan ng mechanic ang carb mo at may gagalawin sya sa idling mo.. kung napansin mo di na sa normal un idling I think na sobra sa idle or linuwagan...
    Try pa adjust sa expert mechanic.. yung mag adjust sa idling first patay ang aircon then on aircon.. different idling if kpag wla kang aircon at mayroon.
    mataas idle- higher gas consumption
    lower idle - baba gas consumption at the engine may stop.
    gud luck!
    May 2005
    fuel injection yung car ko e, hindi siya carburator.
    could be a leak in vaccuum hose or the electronic configuration ng EFI, ibalik mo sa nag-tune up
idling problem
