Results 11 to 18 of 18
- May 2005
- 42
July 23rd, 2005 08:03 PM #12Originally Posted by jeegoogs
Saan po ba exact location ng vacuum diaphragm valve? Sa may carburator ba or sa AC compressor. Ano itsura/shape nya? Hope you can share the info kasi baka po makuha ko sa DIY. Thanks.
Btw, my engine is a Mitsu 4g63 (2000cc) with carburator type fuel system.
Another question po, yun po bang sinasabi nilang servo motor (also, related to idling problem) is only applicable sa fuel injection type?
Hope you can help me. Thanks
- Jun 2005
- 113
July 24th, 2005 02:36 AM #13The problem is with the *Idle Speed Controller* or solenoid.
This seems to be a very common problem with Mitsubishis, it's the second time I'm gonna say that it's probably the most-asked question in the forum.
- Jun 2005
- 113
July 24th, 2005 02:38 AM #14Originally Posted by BongRev
July 25th, 2005 01:35 AM #16
kanina humataw ako sa libis siguro umabot ng 120kph with a/c on tapos biglang tumaas yung idling from 900rpm to 2000rpm hangang makauwi na ko sa rosario? bkit ganon?
July 25th, 2005 08:18 AM #17
Ching, I have been having the same problem lately and I also have the same symptom as yours in another thread. Kahapon, napansin ko yung ACCELERATOR CABLE ko na na parang "nakatiklop". So it seems that if you hit the accelerator so hard, parang nde na bumabalik sa original location nya. Bibili ako nang bagong cable later. 'Hope it solves my problem.
Isa pang problem ko eh pag nag start ako tuwing umaga, ang baba nang idling, 500-600RPM lang. So ang siste, gagamitin ko pa din yung auto kasi after mga 5 kms na andar, babalik n sya dun sa desired idling ko. Pero may mga times na bumabagsak pa din. Although, nakita ko yung problem sa accelerator cable, I cannot think of any correlation between that and the low idling problem. Hope anyone in this forum can shed some light on that.
