hi guys. sensya na if i seem to have a lot of questions. tanong ko lang sana if my car's idling is normal when aircon is on. car is a 94 honda civic lx.
here's the situation. seems there are 3 stages when aircon is turned on. during the first stage, which is also the case when you first turn the aircon on, idling is set to 900 rpm (which is also my rpm w/o aircon). the second stage occurs after about a minute, this is when i think the aux fan kicks in. rpm increases to 1k and you can hear a humming sound. again after a minute, idling drops to about 300 rpm and goes back to 900 rpm after a second or two. this is when the aux fan stops.
when the car is moving, you can somehow feel the loss of power pagdating sa third stage. this is true especially if you're coming from a full stop tapos kelangan mo na umarangkada. kapag inabutan ng third stage while beginning to accelerate, kelangan i-compensate sa pag-apak sa gas pedal, otherwise medyo nanginginig makina.
this is my first car and i haven't driven any other car kaya wala ako ibang basis. and since im a new driver, ngayon ngayon ko lang napapansin ung mga nuances ng kotse kaya im not really sure if this was the case before. im wondering if this should really be the case for cars with the same age or any car for that matter.
btw, napapalitan ko na ung vacuum hose (the one where i think 5 other hoses are connected sa may bandang carburador). previously kase natanggal to and niremedyuhan na lang ng mighty bond. before replacing it, i was already experiencing this idling condition with aircon on. twice ako namatayan ng makina nung dumating sa 3rd stage when i was at a full stop. ngayong napalitan na ung vacuum hose, hindi pa naman ako namatayan uli (crossing my fingers here). last tuneup naman nya nung october.
concerned lang kase ako kung normal ba talaga na ganun kababa bagsak ng rpm pagdating ng 3rd stage though umaangat din naman after a second or two. in addition, kapag nasa 2nd stage naman, although nasa 1k ang rpm, feeling ko mukang medyo noticeable ung ingay and baka masyado malakas sa gas at this stage.
really appreciate your inputs. dami ko na natututunan dito sa tsikot and im really eager to learn more. TIA!
