Results 1 to 14 of 14
    Apr 2005
    mga sir, ask ko lng po kung ano kya ang problem,
    na experience ko po kc couple of times na pag naka on yung aircon then nag engage ang compressor biglang bababa yung rpm parang mamatay ang car. split second lng eto. after nyang mag ganun ok na sya. pasulpot sulpot kung mangyari po eto...
    car ko nga pla po lynx RS.
    thanks in advance
    Try mo pa-check wiring ng aircon mo. Problem ko dati sa Civic ko kapag nag-off yung compressor bagsak rpm to the point na namatayan ako makina. Akala ko nung una idle-up problem. Kina Mang Mario ko dinala naayos naman. Although check mo din idle-up mo baka may problem din.
    seems mabigat na i-drive yung compressor though initially lang
    naman but it's not normal dahil extra load ito sa engine.
    Apr 2005
    thanks sa mga reply,,, pero sir yung akin kc matagal na naka on yung aircon bago mag ka ganun... talagang may tiyempo lng siya, anyway papacheck ko n din para mas sure ako..
    Jul 2006
    Check mo idle up system
    Quote Originally Posted by mbeige View Post
    agree on this, sabayan mo na din kaya ng pa linis ng throttle body.
    Apr 2005
    Quote Originally Posted by artpogi View Post
    cge sir daan ko sa casa, pero 7k plang po mileage ng car ko pero 3 years na sya.
    sana naman linis lng katapat.. hehehe
    Quote Originally Posted by arvic View Post
    kung hindi makuha sa cleaning or if idle-up mechanisms & wirings are working ok, u might wanna check the compressor itself. seems that at a particular point, the load suddenly gets high causing a big dip sa power thus namamatay makina. baka may bearing na nag-ii-stuck up.
    May 2005
    parehong pareho tayo problem sir. kaso diko pa napapa-ayos yung sakin.
    nawawala din lamig kapag naka hinto. tapos babalik nanaman lamig kapag
    mabilis na ang takbo.
    palit ka lang daw ng rims to 17s....aayos na yang aircon mo.
    baka nga linis lang yan bro.
    Nov 2003
    check lang to see if the tb is dirty. if it is then have it cleaned. it's probably the cheapest 1st step.
    Apr 2005
    Quote Originally Posted by baiskee View Post
    nyahahaha.... tsaka na yung 17's pag nagsawa na ako ng stock mags...
    sana nga linis lng... napapasin ko din pag naka stop humihina yung aircon pero malamig pa din over all...
    *speedyfix pwd ko pa pa check sa inyo? mahal kc sa ford libis diagnos palang mahal na...
    Nov 2003
    sure no prob
    Apr 2005
    Quote Originally Posted by speedyfix View Post
    sure no prob
    thanks sir....
idle when aircon is on
