Results 11 to 20 of 20
October 22nd, 2006 10:30 AM #11
check the following:
1. Electrical (specifically grounding as everyone has mentioned) plus alternator load if it is sufficient.
2. A/F mix. pag di balanse pumapalya ang idle.
3. clogged fuel line not enough fuel is being supplied sa carb and too much air is entering the system.
4. your tensioning pulley baka pigil na ang ikot need to replace bearing (hirap ang makina pag ganito at common ito sa mga old model cars like our corolla)
5. did you change HT wires when you changed your sparkplugs???
6. palitan mo na rin yung distributor condenser mo at contact point.
ganyan din yung corolla ko dati pero after ko ipa-tuneup at palitan ang kelangan palitan ayos na.Last edited by jim; October 22nd, 2006 at 10:33 AM.
Toyota is my choice
- Aug 2005
- 2,063
October 22nd, 2006 10:32 AM #12check carb timing and idle up mechanism lng..
October 22nd, 2006 10:36 AM #13
tama si Finchy yung idle-up mechanism pa pala hehehe pero yung ovehaul saka na pag walang improvement na nangyari after checking everything
October 22nd, 2006 10:51 AM #14
October 22nd, 2006 10:55 AM #15
October 22nd, 2006 11:05 AM #16
may screw sa likod ng carb nasa gitna. what you do is to turn your engine on in idle then tighten the screw clockwise. when the engine starts to vibrate badly, loosen it turning counter-clockwise until all bad vibrations are gone. don't overdo yung loosening or else you get bad fuel consumption. this is just a rough setting but it works for me
you may wanna visit this site http://www.grupotoyota.com.ph/board/ maraming experts sa toyota dito.
Toyota is my choice
- Aug 2005
- 2,063
October 22nd, 2006 11:08 AM #17YEp... thats the signs na busted na idle up mechanism mo.. na exprienced ko na to.. I neglect to replace it coz it's still working..pero namamtayan na ako which is WORST. it's really bad coz the vacuum is working On and off... so why not replace it? surplus would be good. 400 pesos ata un nabili ko. I have a mitsu idle up mechanism and it works fine. toyota or mitsu is good.. It is a surplus.
ganyan talaga idle up nayan minsa ok minsan hindi. ang nakaka asar nito is hindi makita ng mechanic dahil pa minsa minsa lng lumalabas. hehehe.Last edited by finchy18; October 22nd, 2006 at 11:18 AM.
Toyota is my choice
- Aug 2005
- 2,063
October 22nd, 2006 11:15 AM #19
check fuel pump too...
kung elec. fuel pump pa check mo baka pumapalya na, kung mechanical, baka mahina na...
October 22nd, 2006 01:58 PM #20
I cant believe what happend after a short discussion with you guys it solves my problem after a 2 LONG weeks nagging at my car, I lost my meals kakaisip but finally, lecheng grounding lang pala ang problema ko.
To all you guys na nag comment on my problem, MARAMING SALAMAT PO!!!.
PROBLEM SOLVE. yehey....
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
