Results 1 to 10 of 20
October 22nd, 2006 09:03 AM #1
mga sir,
May mga katanungan po sana ako tungkol sa corolla ko.
1. pang minsan ok ang minor, pero may pag kakataon na pangit umandar as in bumabagsak sya, tapos ang masama pa nito pang nag load ka ng aircon tataas bahagya ang minor, tapos drop na sya unti unti which is nakaka asar ihandle ang pag gannon kondisyon.
2. may mga oras naman na ok na ok, smooth ang andar.
nag palit na ako ng ignition coil, spark plugs, ok naman carburador kasi hindi naman sya nag cho choke.
Ano kaya problema pa nito, sana matulungan nyo ako or may mag volunteer na mekniko na pede gumawa. hopeless case na ako eh..
help naman po..
October 22nd, 2006 09:25 AM #3
October 22nd, 2006 09:27 AM #4
well, last na yun, kakaisip ko lang..
pcheck mo ung ignition timing, pati valve clearance, one of the causes din yan..either masyadong delayed yung timing mo...
in short, try mo ipa-general tune-up
October 22nd, 2006 09:31 AM #5
try mo i-overhaul yung carb mo. most likely nandun ang problema. baka fouled-up na yung throttle plate.
yes, tama, si always_yummy. grounding din. may mga mods ba yung kotse mo botyok?
October 22nd, 2006 09:35 AM #6
October 22nd, 2006 10:02 AM #7
talagang pinapalitan yun. hehehe. kung grounding kits ang kelangan mo check this out:
http://tsikot.yehey.com/forums/showt...ounding+Kit%2A
i've always admired the AE92 corolla.
October 22nd, 2006 10:05 AM #8
diesel kasi ride ko,e... liteace diesel...groundin sa ride ko magbebenifit ang ECU, heaters at acc...unlike sa gas na spark ignition..
October 22nd, 2006 10:27 AM #9
October 22nd, 2006 10:29 AM #10
Babala! Sarado at Ginagawa mga south bound flyovers along c5. Medyo mabagal Ang daloy kanina Ng...
Traffic!
