Results 1 to 5 of 5
- Apr 2010
- 71
September 14th, 2013 01:41 PM #1Hello tsikoteers, just want to ask if what could be the possible culprit when the rpm is dropping whenever the car is in free wheeling mode?
Ride is honda 92 / PH12 engine / MT. Any response will be highly appreciated. TIA
September 14th, 2013 02:44 PM #2
When the car is at standstill, the idle is also too low? How about when the car is just started (cold start)? That's a carburetor engine right? Simple idle and A/F adjustments won't cure it?
- Apr 2010
- 71
September 14th, 2013 04:21 PM #3No sir. The rpm is stable and steady at 800 while idle
Ive been having a cold start issue for the past months, but literally, just a cold start (or in every morning) cause once the engine starts, it will be just one click all throughout out the day.
Yes
[QUOTE=vinj;2226119Simple idle and A/F adjustments won't cure it?[/QUOTE]
Hmmmmm, the carb was already overhauled by the experts in kamuning so I think it was properly handled.
- Jul 2010
- 570
September 16th, 2013 08:44 AM #4Looks likes you have an engine Timing problem. Pa check mo Timing ng engine and be sure that small vacuum hose from carburator was connected properly to distributor vacuum advance diaphragm ( Flying saucer ).
- Aug 2008
- 405
September 16th, 2013 12:13 PM #5I also have this intermittent problem on my 04 civic vtec. Any idea on what might be the problem?
Methinks the Battle of Carthage scene in Russel Crowe's Gladiator (yr. 2000) is a homage to that...
Traffic!
