Results 11 to 20 of 27
- Apr 2010
- 65
June 29th, 2010 02:38 PM #11
- Apr 2010
- 65
June 29th, 2010 06:01 PM #12Oh one more thing, i just got my aircon repaired so i had to set my idle at 1100 para nasa 800 pag naka on ac, pansin ko lang ayaw pumasok sa gears nung paalis na ako, un feeling eh parang pag try mo isaksak sa 5th gear pero wala naman 5th gear, un ganon, related kaya ito sa pag set ko ng idle sa 1100? ty!!
June 29th, 2010 06:51 PM #13
Dear joyluck:
The difficulty you are experiencing in shifting into gear is EXACTLY what I was talking about.
When the engine's curb idle speed is TOO HIGH, the synchronizers in a manual transmission will have a harder time equalizing the input vs output shaft speeds, resulting in the harder, more difficult shift.
When you step on the clutch, the release bearing is forced onto the diaphragm spring of the pressure plate, releasing the clutch disk from the flywheel, thereby dis-engaging the transmission from the engine.
This allows you to change gears, pushing on the gear lever does several things sequentially very quickly:
1) after selecting the desired gear and bringing the shift lever into the correct position, the 1st part of the push/pull forces the cone clutches together
2) the cone clutches are responsible for equalizing the speed of the input and output shafts
3) when the 2 shafts start turning at the same speed a toothed ring - called the synchronizer - slots into place, allowing -
4) a locking sleeve (called the 'dog sleeve') to slide and lock the two shafts together.
That's how a gear is selected and changed.
No doubt you've experienced a grinding noise and feel during a bad shift.
That's not caused by the transmission's gears themselves (which are always engaged) but by the synchronizer and dog sleeve refusing to engage and lock.
No when a transmission gets older and worn, those parts get a little loose, making it more sensitive to things like engine idle speed.
Keeping your idle speed low makes it easier to shift.
Best Regards,
Dusky LimLast edited by duskylim; June 29th, 2010 at 06:58 PM.
- Apr 2010
- 65
July 2nd, 2010 02:31 PM #14Thanks once again Dusky, i lowered my idle speed down to 950 so when ac kicks in its around 700-750, comfortable enough not to make my engine vibrate.
Havent had a hard time shifting since then
- Apr 2010
- 268
July 3rd, 2010 12:44 AM #15Why is mine the exact opposite? When my AC turns on my idle doesn't go down. Shoots up to 1000? That would be fine right?
July 3rd, 2010 11:42 AM #16
Dear sheperd:
The reason your idle speed goes up is because the FAST IDLE system (aka Idle Up system) is working correctly.
As I said BEFORE - the carb has a device used to raise the idle speed when it is necessary to drive accessory loads like the A/C.
In the case of joyluck he lowered his FAST IDLE speed to make it easier to shift.
Generally the Fast Idle system brings the engine RPM to around 900 to 1000 rpm - UNLOADED, but the load of the A/C will lower that speed to around 800 to 900 rpm.
If your fast idle speed is 1000+ rpm with the A/C ON, that's a little too high and will make your shifting more difficult and consume more gas.
The upside is that your A/C will cool very quickly.
Note: Please read the previous posts so we don't have to keep repeating ourselves.
Thank you.Last edited by duskylim; July 3rd, 2010 at 11:51 AM.
- Apr 2010
- 268
July 3rd, 2010 12:00 PM #17Thanks for making that clear. Looks like I need to adjust the fast idle speed again.
Another thing. Sir Dusky,
Which creates poorer FC, exhaust pipe with smaller inside diameter than stock or exhaust pipe with larger inside diameter than stock? And also why? I just need to know the effects.
Thanks again!
- Apr 2010
- 65
July 5th, 2010 03:07 PM #18
- Apr 2010
- 9
July 7th, 2010 08:51 AM #19Sir Dusky,
Would you happen to know where is the adjustment for a corolla 16v GLI 4afe engine? My car will not compensate for the extra load of the AC. When I am not using AC the idle is on 1,000 RPM when I use AC it goes down to half and the engine is choking, and i have to rev up the enginge to give it a boost. Thanks in advance.
July 7th, 2010 10:54 AM #20
Dear belle:
Isn't the GLi series of Toyota Corolla FUEL-INJECTED?
If so, you cannot adjust the idle settings without knowing how to set electronic fuel injection systems.
As most fuel injection systems are electronically (computer) controlled with various sensors built into the engine, you need to have the diagnostic system (test computer system) to adjust it correctly.
You will have to bring your car to an injection specialist or sa casa.
If I'm wrong and your Corolla is carbureted, then go back to the old posts of this thread, the same advice I gave before applies to you.
Sincerely,
Dusky Lim
Even on Brave (a chromium based browser) the textbox is really short. Started happening after that...
Problems with viewing Tsikot on non-Chromium...
