Results 11 to 19 of 19
May 20th, 2003 10:08 AM #11
ung sa pick-up.
fuel filter - 10,000km
oil filter - 5,000km
air filter - di ko lam
ung sa escape ngayon pa lang malapit na 1st 5,000km nya
May 20th, 2003 12:51 PM #12
primary fuel filter.. every month at most 3 months
secondary fuel filter every 3 months.. at most half a year
air filter.... hmm. nde pa ako nagpapalit since June 2002.. ehehe.. linis lang ng air comp. ehehhe
May 20th, 2003 07:52 PM #13
Same sked as dieseler's. I just use the generic air filters.
May 20th, 2003 10:20 PM #15
every 10K kms.
I just use the VIC japan replacement parts. (its VIC or Mitsu only).
Tsikot Member Rank 3
- Dec 2002
- 636
May 24th, 2003 09:04 AM #16There are 2 types of air filters: dry and wet. The dry type can be cleaned with air while the wet type can be brushed clean since it has an oil which contains the dirt, dust. Some filter manufacturers don't recommend using pressurized air on wet type filters. Think the filter media which is colored white is the dry type while the pink colored ones is wet.
The trooper's (4JX1) air filter is a wet type filter. Either one, i replace air filters at 10k km.
May 26th, 2003 02:14 AM #17
e kung palitan na lang ng racing filter?para linis na lang instead of palit every time?
Tsikot Member Rank 5
- 3,144
May 26th, 2003 09:39 AM #18Ako, I opted for orig isuzu filters for air, oil and fuel.
Sa air, in particular, wala akong mahanap na full rubber on both ends, kadalasan ng nakita ko ay ring lang ang rubber. Yep, pink ang color nito.
May 26th, 2003 11:50 AM #19
Changing to an aftermarket filter does help in replacement costs in the long run... However i'd suggest you save up for a K&N filter and cleaner kit as this will still be better in longevity and filtering quality. Simota's are pretty cheap but they have a lower level of filtering quality and longevity then the K&N filters.
Just keep your stock airbox so if you plan to cahnge cars, you can carry over the K&N as long as you take good care of it.
Choosing one would depend on your driving and parking conditions. Do you have your own garage =...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
