Results 21 to 26 of 26
- May 2008
- 15
May 1st, 2008 10:11 AM #21the valve clearances can be adjusted on a machine shop. I had mine for 6k in Pasig. They changed the seals and adjusted the clearances.
My eccs sentra still emits smoke going uphills and on high rpm with Engine "tope". Same problem before doing the top overhaul.
Please help.
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 4th, 2008 04:30 PM #22you can't remove builder or machine shop error from the mix. if the build or lapping was not done correctly then kahit ano padala mo sa machine shop, or ilan beses mo ipabukas makina hindi maaayos yan.
enzo18, our estimates are free naman but in most cases like this you really cannot tell what exactly needs to be replaced until you start opening up the engine to actually do the work.
- May 2008
- 15
- Nov 2003
- 3,849
- May 2008
- 15
- Dec 2008
- 22
December 6th, 2008 07:23 AM #26hi there, i owned an old model car, 4k gasoline engine, kka top overhaul lng, pinalitan ung valve seal kc lagi me napupundihan ng spark plug before. Ginagamit ko n ngyon kaso pg tiningnan ko ung temp gauge mejo mataas, talaga bng ganun ang temp pag bagong top overhaul?
Suzuki JIMNY [merged threads]
