Results 1 to 11 of 11
    Nov 2007
    fuel pump most likely kumakadyot ung sasakyan mo parang naghihingalo cya
    try chocking carbs and clean up na rin may nabibili namang pang linis mga 200 petot ata un
    check fuel filter baka madumi na rin and time to replace na
    wait na lang natin ibang mga expert dito
    Oct 2008
    sir, tnx for your input. But, i do newly change oil and minor tune up this last first week of november done by shell. But. when i tested kanina, pag start ko, one click nalang siya at parang stable naman stats ng makina nung inikot ikot at binirit ko. Anu kaya nayari kahapon sa auto ko?
    Fuel filter?
    linisin mo yun throttle yata ang tawag, ganyan din yun series 3 ko before bumili lang ako ng carb cleaner then spary ko lang...
    and no need na mag painit ng makina sayang lang gas mo
    Sep 2004
    Quote Originally Posted by jansky View Post
    ECCS yung sasakyan niya, kaya walang karburador.
    IMO, it's a fuel-realted problem. Either the fuel pump is malfunctioning (sometimes gumagana, sometimes hindi) or a dirty fuel filter (nung natanggal yung bara, ok na).
    Oct 2003
    check the fuel filter. kalasin then taktak mo. baka madumi na.
    kung madumi na nga, replace it.
    Oct 2003
    puede din electrical. check high tension wires, spark plugs, computer box
help sirs, my engine dies and stall.
