Results 11 to 17 of 17
Tsikot Member Rank 4
- Oct 2004
- 2,315
May 19th, 2005 08:31 PM #11same problem. Parang pag mainit nangyayari sa gsr ko. Parang kinakapos ng hangin sa higop sa airfilter. Mahina din pasok ng kuryente ko kaya hindi ako nakapaglagay ng monster tach Ano kaya ang magandang gawin. Pinacheck ko na sa rey's dati pero wala naman daw problema
May 19th, 2005 09:05 PM #12
ako din ganyan problem dati, 1994 Honda Civic 1.5LX MT.. first, pinaoverhaul ko ung carb, ganon pa din ngpalit ng fuel filter ganon pa din, tpos pnacheck ko sabi may "crack" na yung ignition coil sa distributor kaya replaced it, ganon pa din, then last one is i replaced the "magnetic switch" nung carb, tpos since then no problem! woohooo!
May 19th, 2005 09:12 PM #13
pwede rin servo... yun problema ko dati... high-tension wires palit, distributor pinaayos, fuel pump, fuel filter, air filter, etc... dami sobra! 1996 mazda familia glx... yan lang ang tanging sakit ng ulo nun sasakyan
- May 2005
- 3
May 23rd, 2005 11:56 AM #15ganyan din prob ng sasakyan ko more inputs pa po bago ko pagawaan car ko
- Mar 2005
- 23
May 23rd, 2005 12:30 PM #16hunch ko lang...How about the fuel pump, di kaya it does not pump enough gas on some occasion to the engine, there are cases kasi that if marumi yung carboreator or fuel filter...na dadamay yung fuel pump...yung mga rubber seals sa loob nag bloc..block yung gas to the engine....
- Dec 2004
- 384
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
