Quote Originally Posted by ibysa View Post
Hello po. I'm a newbie here. Magpapatulong po sana ako. I need your advices po. My car is a '95 Nissan Sentra Super Saloon (GA16 yung makina)
Recently, my car engine overheated. Naghahalo yung oil and tubig. Dinala ko sa isang car care shop, unang diagnosis was top overhaul lang. Tinanggal na nila yung cylinder head then sabi nila may linya na daw yung liners kaya ipapagawa na din sa machine shop. Pinaresurface yung cylinder head, pina grind yung crankshaft, nagpapalit ng sleeve, piston at piston rings, valve seals. Took a week bago nagawa, then kinabit na lahat, changed the oil. Nirelease na after days, pero sobrang usok kaya binalik ko then nakita na humahalo pa din. Ang ginawa na naman sa cylinder head is pina hydro test then wala naman nakitang crack, pero sabi nung mekaniko may nakita daw silang crack palitan na daw yung cylinder head. So yun, nagpalit kami ng surplus worth 16k. Pina overhaul din yung radiator.
Then ok na daw, hindi ko pa masyadong ginamit kasi mausok ng sobra pero dahil lang daw yun sa sinusunog yung bagong parts. I checked the radiator cap naghahalo pa din yung oil and water. Ang sinasabi ng mekaniko is may tama na naman daw yung cylinder head. Ang pinagbilhan ko nun is a credible dealer of car parts (CBROS) and kakilala namin so good one yung binigay. Ano po ba sa tingin nyo yung sira? Yung mekaniko kasi parang hindi naman talaga marunong pa. Gusto nya palit lang ng palit hindi nya naman nakikita kung ano talaga yung sira. Sorry po for the long post. Please help thanks a lot po!
Sent from my ASUS_T00J using Tsikot Forums mobile app
Tsk. Mahirap to wala sa harapan ko ung engine at di talaga makita. Pero kung tiwala ka na okay head mo, at sabi mo nga pinapalitan ng sleeve... Pag di magaling mag re-sleeve at mag deck ng block ung machine shop, pede lumubog ng kaunti sleeve enough to cause the sharon cuneta and smoke machine.
