Problem Description
While doing a reverse on a very slightly uphill curve, the car engine stalled but with all electrical devices still running (ie Aircon, headlights). I turned off the car but it wont start again. There was no crank when I tried to start the engine. What baffles me is this constant humming sound when the key is in "on" position.
A Newbie's Attempt to Resolve the Issue
I checked the battery power/terminals/life; it seemed ok... everything is running bau (ie Aircon, headlights, wipers, horn). I just had this car tuned up before Holyweek. I was completely bummed out.
Call a Friend
Starter solenoid problem? Alternator? Fuel Pump/Relay? Timing belt perhaps? I thought of these things but I wanted to be in denial. It's 1130pm, I'm not sure if there is a mechanic available to service my car. I'm about to panic. I don't have cash with me (300php lang). I skipped my usual atm withdrawal due to the "mala-nora aunor movie line" at cybergate.
I called Kuya Boy (driver ni Lolo) na lang for consultation. He told me na it could be one of the three above. Na I could have it towed (waaah, 1K daw ang tow..putek mahal) na lang, drop it at my Lolo's house at Pasig. Then, he could look into it the next morning.
It's a Miracle!!!
After succumbing to his idea, I was asked by the guard to move the car so it will not pose as a risk to other drivers. At this point, I was thinking.. "automatic to di mo pwede itulak, pano kaya to?". But I remembered na may power sya. So I asked the guard and my colleague to push the car after I put the key in "on" position and put the gear in neutral.
After this exercise, I prayed that sana mag start na sya. One last try bago mag cab pauwi. Not realizing that I left the gear in neutral, I keyed in the key then tried to start the engine. Lo and Behold, the car cranked and it finally started. Weeee!
I need your input
What do you think happened? I'll be bringing it in to have it checked pero it would be nice to get numerous diagnosis. thanks!
Notes
- My car is a 1998 Lancer GLXI Automatic
- Timing belt was replaced by CASA back in 2005
- Tune Up and Change Oil done a wk before Holy Week
- I drove the car from cybergate to central (mga 1Km lang ang layo)
- naka full tank ang kotse
Thank you po sa mga magiging inputs ninyo peeps.
