Results 11 to 14 of 14
June 18th, 2004 01:21 AM #11
If the casa is too expensive for you. You can try Delta Motors. There's 1 near Cubao, 1 in Marikina, as far as I know. They specialize in Toyota cars but significantly cheaper than Toyota casa itself.
I had my idling fixed there too. My problem was only a clogged throttle body and the whole thing was solved by cleaning. I don't know exactly what's the problem with yours but I'm pretty sure the mechanics there can provide you with a remedy.
- Jul 2004
- 1
July 13th, 2004 10:30 AM #12Pre, baka may singaw ang intake manifold gasket mo. one way to find out is to get a fropane torch (sumisingaw na walang sinde) then bring it closelly all around to the gasket and when the engine speed or RPM increase thats it.
- Mar 2006
- 58
September 27th, 2006 02:38 PM #13Ganun pala yun, baguhan lang kasi ako sa kotse and akala ko normal yun habang naka-idle ako, 1k RPM ko.. Actually pagstart ng kotse ganun, 0 lang siya kapag patay makina. Using a 2000 Hyundai Sonata GLS. SO dapat pagkastart ng oto, 0 rpm bsta idle
Tsikot Member Rank 5
- Nov 2003
- 3,849
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
