Results 11 to 20 of 30
November 12th, 2006 01:05 PM #11
November 14th, 2006 03:12 PM #12
pareho ata tayo ng problema bro. iyon nga lang wala akong voltmeter kaya di ko alam kung sumasabay ang bagsak ng kuryente. pinatingin ko sa mekaniko ko pero di ma-remedyohan. patay sindi tuloy ang compressor ko pag naka-on ang aircon. malinis naman daw ang intake manifold. di lang na-check yung throttle body at yung iacv. saan ba located iyong iacv? help!
btw ang kotse ay '96 civic vti
November 15th, 2006 02:58 PM #13
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 16th, 2006 12:37 AM #14if your mechanic cannot tell you where the iacv is then change your mechanic.
November 16th, 2006 01:00 AM #15
*speedyfix, hahahaha!
*mamar, it looks like your IACV is stuck.
quick test: pag malamig yung makina, mataas ba yung idle? tapos as the temp rises bumababa siya to normal 700-800rpm level? if so, the IACV is still working (kind of).
the symptom na when you press the gas and then release, hindi bumababa agad yung idle, seems like dirty IACV not responding quickly enough anymore. also try to check your coolant level because air in the coolant system can affect the IACV's operation (jumping idle).
kayang linisin ng DIY yung IACV, pero don't expect massive improvements. i think when the car gets old idling problems become prevalent, this seems to be common to all brands and makes.
but if i were you, i'd try cleaning the IACV first. in my case it was fouled with so much carbon kaya hindi na siya nag-re-respond quickly.
November 16th, 2006 08:40 AM #17
hehehe
honga eh. makes me wish i live closer to your shop more and more
anyhow, i'm in the mood for an attempt in diy-ing this stuff. i understand pwede silicone spray tirada dito. any tips? spray lang ba sabay punas sa iacv at patuyo? ganun din sa intake manifold and throttle body?
November 16th, 2006 05:15 PM #18
you need to remove the IACV from the throttle body, disassemble it (don't lose the teeny tiny cap and screw inside) then either wash it with gasoline, or douse it with carb cleaner.
took me a whole afternoon, and i dropped the teeny tiny brass cap _into the throttle body_ (got a big scare there.. good thing i was able to extract it with a tweezers, i don't want to think what would happen if it fell into the intake manifold and got ingested by the engine.. instant broken engine).
- Nov 2003
- 3,849
November 17th, 2006 07:47 AM #19baludoy, actually regardless of where you are, you should know when you know more than your mechanic. when that is the case then take your car somewhere else.
November 17th, 2006 08:45 AM #20
^ point taken bro
medyo excited na ako sa diy na 'to for the weekend
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
