Results 41 to 50 of 56
September 6th, 2015 02:12 PM #41
September 6th, 2015 04:33 PM #42
Sir miko101130, sabi nung machine shop #3 na balak niyang lagyan na lang ng "liner" yung mga cylinder kasi less than .25mm daw ang difference. Yung mga "liner" ang tatabasan nila para magkasya yung original piston heads na puede pa naman daw, magpapalit lang ng piston rings. Mas mura daw yon compared sa magpalit ako ng oversized piston heads. Wala naman daw difference sa performance.
September 6th, 2015 04:54 PM #43
A .25mm liner sa cylinder. Thats 2x the thickness of coke zero cans. Will that be done on 4 cylinders? Paano kaya magagawa yan?
Engines are blocks of metal so heat transfer is ideal. A liner in the cylinder sounds sketchy imo.
September 6th, 2015 05:14 PM #44
Yup it's the right thing to do. Put liners on all 4 cylinders and hone it to match the piston and clearance for the piston rings and it's good to go. You need to use an oversized piston ring and shave it to the exact clearance of the liners. Buy original rings in this case.
It's best to put liners instead to re bore your block. Also cheaper as you will not buy new pistons. Only the rings will be new. Critical here is the clearance of the rings. If done wrong your engine will have loose compression later on and will shorten the life of your engine. If done right 7 to 10 years is good maybe more it will depends on your maintenance
September 6th, 2015 05:24 PM #45
Sir StockEngine, wala po kasi akong alam sa mechanical and yun lang po ang naintindihan ko sa explanation nung machinist. Hindi ko rin nga maintindihan kung paano niya mapadikit yung liner sa cylinder considering high pressure duon and supposedly akyat-baba ang pistons duon... Pero ok naman daw yun sabi niya. Walang difference in performance daw.
September 6th, 2015 05:28 PM #46
The machine shop will rebore your block to accommodate the liners. Just make sure they use a good liner. There are liners kasi na mahinang klase. I forgot the brand of liners our mechanic use.
Performance would be back to 1.5 using liners but if you just rebore your block to the next bigger size then your engine would have an increase in displacement. Like maybe 1.6
September 6th, 2015 05:32 PM #47
Yes po, Sir SkyFlakes, original piston rings nga ang sabi nung machinist. Clarify ko lang sa kanya kung oversized yung ipabibili niya.
As for the competence level of the machine shop, okay naman daW ang experience ng oWner ng Auto supply na malapit sa kanila. Madalas kasi ako bumili duon kaya tinanong ko yung may-ari. And kilala naman yung machine shop dito sa lugar namin kasi matagal na daW yun.
September 6th, 2015 05:39 PM #48
September 6th, 2015 05:45 PM #49
Your good to go then Sir. Don't forget to ask for warranty sa machine shop at sa mechanic. Also after all is done you will have to break-in your engine. Meaning no a/c till you get to 1k kms. Our mechanic has a system where he release his newly overhauled cars in semi break-in condition already. This shortens the km needed so you can use your a/c asap
September 6th, 2015 05:48 PM #50
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
