Results 1 to 4 of 4
    Dec 2004
    mga gurus...need your help again...paevaluate naman series of noise problem
    ride is, MITS 7G '96, MT
    1. once you turn the ignition on (on only not start) there is a momentary unusual sound that can be heard in the engine.
    say, turn engine on > simultaneous, engine light on and sound in the engine (tsuk-tsuk), yes twice lang, then wala na > engine light off
    the car will start without a problem.
    2. when the car is running, say * 60kph up, there is a audible (though not loud) whistling sound from the engine. this sound is intermitent.
    3. when decelerating, a metal-sound like noise can be heard from the rear. particularly at the left back side. the sound is similar to a tin lid thrown on the floor, e.g tin cap of an half-gallon ice cream.
    Have check the brake pads and rotors at the rear, okey naman.
    IMO, items 1 and 2 are possibly related. Item 3 may be a suspension case.
    Help please! Thanks!
    1. Fuel pump priming yun, don't worry about it.
    2. Could be air leak sa mga weatherstrips... Not engine related... Other than that, I can only think of expansion valve (A/C) noise.
    3. Baka sira na stab link or bushing. Check brake caliper as well.
    Aug 2004
    1. Could be your servo doing its self-test. Normal.
    2. Check hoses. It could be coming from other sources aside from your engine though.
    3. Clang!!?? Have it checked ASAP :D
    Apr 2005
    1. Yung 'tsuk-tsuk' could it be one of the relays?
    2. Whistling sound - is it only when * 60kph, regardless which gear?
    3. Tin can sound could-it be from the muffs or the resonator?
Help! Engine Noise When Turning On The Car
