Results 11 to 20 of 22
November 25th, 2005 02:52 PM #12
dont expect too much "hatak" in 5th gear. its already overdrive in most cars.
- Oct 2005
- 13
November 25th, 2005 08:01 PM #13salamat sa mga info bro.car ko ay toyota celica efi sya no carb.naninibago kase ako eh d naman sya ganun date eh wala nmn akong alam sa mga makina bsta drive drive lang kya hingi ako tulong.so pag timing ang prob kailangan ko palitan ng timing belt?or meron pang ibang dapat ayusin pag timing ang prob?tenks ulit
Toyota is my choice
- Aug 2005
- 2,063
November 28th, 2005 11:39 AM #14Originally Posted by banshee
November 28th, 2005 11:43 AM #15Originally Posted by banshee
- Oct 2005
- 13
November 28th, 2005 03:04 PM #16pinaadjust ko ung timing mdyo nagiba na ng onte tapos papalitan ko na ung mga belts.but medyo happy na ako ulit sa takbo nya but dpa kuntento.gusto ko ng bmalik sya sa normal.sna ung mga belts na ang solusyon sa prob ko.hahay
November 29th, 2005 05:11 PM #17Originally Posted by bebang_bitoy
any feed back.
November 29th, 2005 05:25 PM #18
oo nga po, mostly dont expect much pull from the top gear as it is often times the overdrive gear. some cars even achieve their topspeed a gear before it... eg Acura RSX has 6 gears 6th gear capable of 132mph while the 5th gear can squeeze 140+mph.
- Oct 2005
- 13
December 2nd, 2005 06:10 AM #19pinaadjust ko ung timing.sabi nmn nung isang mekaniko barado daw exhaust ko kya walang response pag tinapakan ko ng husto ung gas.date d nmn sya hirap mag 140-160 ngaun hirap na hirap na sya kya cgurado akong me nagiba at me deperensya.
BANNED BANNED BANNED
- 3,790
December 5th, 2005 05:10 AM #20sir banshee, merun bang sira ang keyboard mo o nasanay ka lang kakatext? One of the rules ng board is to type normally and not to type like sending a text message sir...wala naman limit ng number of characters ang isang send...peace
Back to the topic: tingin ko walang problem na malaki kasi nakakatakbo ka pa ng 140kph. Most kalye naman ang speedlimit ay 100kph lang so sobra-sobra pa ang kakayanan ng oto mo.
If you want to run at race car speeds (tutal celica yan), I would highly recommend that you try going to AutoXer's shop (autoxer is one of the posters din dito sa board but mas mainstay siya sa www.kotse.com na site). He can help you a lot to diagnose high-speed your issues.
Iba kasi ang kondisyon ng oto that have to run high revs and speeds compared to a normal drive situation....for all you know merun speedlimiter yan kaya ganun....or other issues (including the so-called bara sa tambutso which I find absurd).
Kung meron ka kasing problem sa timing, tambutso, EFI injections and/or partly sa clutch...I doubt that you'll even hit 100kph. E nakakalagpas ka nga dun di ba?!?
Sa clutch possible din mag-slide ito at very high speeds so kasama ito sa suspect (consider this kung matanda na ang celica mo - more than 5years old).
Looks like TGPH silently edited the article and removed the entry for Velocita Motors/Ferrari.
Car Sales Data (2024)
