Results 21 to 30 of 33
January 16th, 2014 08:10 AM #21
hay naku ano naman kaya magagawa ng planta sa kaso na ito. share ko lang, last week I had a 2006 civic no start then galling casa, ang naging problema ay bad ground lang (the 12v supply sa crankshaft sensor ay dropping out, catched the glitch by oscilloscope).
i'm not saying na yan problema ng civic nyo but it will help to check all powers and ground.Last edited by t2erns; January 16th, 2014 at 08:17 AM.
- Aug 2008
- 15
- Aug 2008
- 15
January 16th, 2014 11:09 AM #23
January 16th, 2014 12:47 PM #24
that's a good indication that the issue is more likely a wiring issue (power and grounds as I posted earlier)
in my case IIRC it's the ground G101 (hidden beside the throttle body), that ground supplied the ground for the pcm, being intermittent the pcm loses power momentarily. that's the reason the ground supplied by the computer to the coil side of the pgmfi relay is also lost and that will skew the readings of the sensors like crankshaft position sensor and thus the no start condition. the glitch is very intermittent and very fast that no digital tester can catch (I used oscilloscope to catch the glitch).
- Aug 2008
- 15
January 16th, 2014 07:34 PM #25
- Jan 2014
- 3
January 16th, 2014 07:40 PM #26Pa F1 naman po ako
Meron po akong problema sa mitsu El carburetor type kapag coldstart po kasi in the morning pag start mamamatay din agad unless sabayan mo ng acceleration ano po kaya pinaka possibleng problema ng itlog ko mga sir's please pa F1 po ako tnx more power sa lahat ng may itlog
January 17th, 2014 11:30 AM #27
binalikan ko yung first post nyo, bago nasira alternator maayos naman andar ng car? how about the alternator, original ba ang pinalit? may ginawa ba conversion sa wiring ng alternator? na try na ba paandarin na tanggal ang wiring ng alternator?
- Aug 2008
- 15
January 17th, 2014 07:04 PM #28Ngayon lang na detect sira. Sira daw po catalytic converter kaya ayaw umandar makina. Mahal ng quote ng casa for catalytic converter P42K! San po kaya makakamura? Re alternator, denso po nabili ko, kamukhang kamukha po ng stock na alternator at same ang spec. na mitsubishi ang tatak ng oem alternator. Wala pong ginalaw sa wirings. Maayos din po andar nya before
January 17th, 2014 07:18 PM #29
- Aug 2008
- 15
January 17th, 2014 10:09 PM #30Ewan ko nga sir. Pero sabi ng SA nung tinangal catalytic converter umandar daw makina
