Results 11 to 20 of 20
Tsikot Member Rank 4
- 2,716
September 21st, 2006 11:16 AM #11there could be a resistor before the (+) of ignition coil ... hence you should connect to the (+) of resistor, not on coil
September 21st, 2006 12:52 PM #12
I guess the best option at the moment would be to wire directly into the battery and use a relay.
I'll probably tap the trigger wire of the relay into the coil or before the resistor (basically anything that gets 'hot' when the key is turned on).
Ok yung paliwanag ni sir t2erns, sobrang detalyado, per pin na! hehehe.
I hope this works, balitaan ko kayo. Salamat.
- 2,716
September 21st, 2006 01:39 PM #14
- 2,716
September 21st, 2006 02:45 PM #15good luck ... i agree that using a relay is the best way to wire the pump
ford 46 ... dba parang ganyan yung sasakyan ni manuel quezon?
September 21st, 2006 02:57 PM #16
Ito po siya:
With cargo:
September 21st, 2006 03:11 PM #17
Does it supply enough fuel? Di ba V8 ung car na yun?
What about having a separate line with a fuel pump switch installed on the car? Puwede pang anti-theft device siya?
BTW, it's been a long time since I saw that car... parang nakita ko sa Marikina dati... nice job!
September 21st, 2006 03:13 PM #18
Yup. Kaya nung Maruzen na fuel pump since mas malakas ito kahit dun sa original pump niya.
Bihira kasi magamit lately dahil nga sa fuel pump issue. Pero bago na ang mga gulong and ok na brakes ulit.
- 2,716
September 21st, 2006 03:54 PM #19ganda ng oto ... ganda din ng cargo
medyo misaligned ang hood/trim ng oto ... perfect alignment ng cargo
sarap kalikutin yung oto ... ganun din yung cargo
meron yang de-tubo na radio? hindi pa kasi naimbento ang solid-state nung 1946 kahit yung chevy 55 detubo pa rin am radio nya although naimbento ang transistor noong 1948
September 21st, 2006 05:39 PM #20
Hindi na po de-tubo and radio niyan. Modern na po. Stealth-mounted na CD player. Meron ding a/c.
alas, much as we might want to rely on our noses, we may not use our noses to do emissions...
LTO accredited emission testing centers
