Results 1 to 5 of 5
    RE: 2004 Camry 2.4V, During acceleration, there is a heavy vibration that occurs. It stops when you take our foot off the accelerator but starts right back as you get back on the accelerator and continues as you maintain speed. vibration seems to shake the whole car. This problem started after having the 5000km change oil and replaced the oil filter, did not replaced the spark plugs though. What seems to cause the problem? Can anybody suggest a reputable shop who can fix this problem? Thanks
    Jul 2011
    the local toyota casa might know the problem... better let toyota specialist handle the problem considering it might be a serious problem...
    Feb 2009
    Quote Originally Posted by htl View Post
    if the last thing done to your car just prior to the symptoms was an oil change, check the oil level first. it might have been over serviced
    May 2009
    looks like a half-assed job.....
    check mo supports and axle yan maga mahinang parts ng camry
Help! Camry Vibration During Acceleration
